Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Brushes on My Hoover Steam cleaner will not spin
Model F7452900 brushes will not spin. Vaccum is only 1 1/2 years old.
  • 1 more comment
  • Anonymous Nov 26, 2008
    brushes won't spin
  • Anonymous Nov 29, 2008
    brushes will not turn
  • 97roadking May 11, 2010
    is their a manual to fix the problem
We had same problem,Had to have bearings replaced at hoover store/service center. If you bought it within the last year it is under warranty and you wont be charged.
Posted on Nov 25, 2008
Why beter bar dosent spin while in the vaccum mode only in up right position ?
Hello! The air pressure from the motor is most likely spinning the brushes in the upright position. This vacuum has a brush-roll on/off pedal located on the left side of the cleaner. To activate the brushes, power the vacuum on, recline the handle and then press the brush-roll on/off pedal. The brushes should begin to spin. If they do not the belt may need to be replaced. Hope this helps!
Jul 12, 2014 | Hoover Vacuums
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I own a hoover steam vac model f5915-900 and i currently have two problems. 1. the brushes are spinning at a much slower speed. 2. the steam vac is not picking up the water it leaves on the carpet....
the reason the brushes are not spinning is because the belt is slipping, the belt is the bad that connects to the brush to a shaft that makes it spin. Next problam is it is probobly clogged. so water is not going through all the way
Sep 08, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Need to remove bottom brushes of Hoover Steam cleaner F7452900 to clean
Here is the manual that came with the vacuum if you didn't have it already, in it on page 13 of the pdf shows you how to remove the bottom brushes.
www.thinkvacuums.com/pdf/uprights/Hoover_F7452900.pdf
Aug 25, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover f5915
Since the Steam Vac does not have any belts... the logical issue is Switch setting (Hi, Low, Off) on the base cover. The only other is dirt collection on the air intake for the brushes (unit uses air passing over plastic fan blades to spin the brushes). To clear the dirt problem, remove the clear plastic cover located just in front of the brush Switch. You can now use your finger nail (or an old tooth brush) to clean the filter screen located just below the Switch. Don't tear it, just gently remove the accumulated dust/hair.
Brushes should spin once you reassemble and power it up!!
Aug 14, 2009 | Hoover F5906-900 Upright Steam Vacuum
Brushes won't spin on hoover steam vac
Hello tmc68cam. Most vacuums have a belt driving the rollers/brushes. Unplug unit and remove the housing screws to view internaly. If a broken belt note your model# and search for a local applance repair shop for a replacement. IF not I will need Mgfr.,model & serial# to research to futher assist in the repair. Good Luck.
Oct 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Model #5880-900 Hoover spin brush carpet cleaner
i WAS LOOKING AROUND FOR A SERVICE MANUAL FOR MY F5897900 CARPET CLEANER AND I SAW SOME THING ABOUT HAVING TO "PRIME" THE PUMP. YOU PPARENTLY TAKE THE TOOL HOSE AND HOLD YOUR HAND OVER IT FOR ABOUT 15 SECONDS. THIS MAY OR MAY NOT WORK.
ANYBODY KNOW WHERE I CAN FIND A SERVICE MANUAL FOR A HOOVER CARPET CLEANER? SEEMS TO BE A VERY CLOSELEY GUARDED SECRET.
RON
Sep 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
341 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
