Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Water dispenser quit dispensing water
Kitchenaid side-by-side Model #KSCS25FKSS00. Water dispenser quit dispensing but icemaker continues to work fine.
Filter light was red so I replaced the filter. Filter light remains red and still no water from dispenser.
  • ronp_sa Nov 24, 2008
    How do I remove the dispenser? I've checked and it's not immediately apparent how I do this.
    Also, does blockage in the dispenser explain why the filter light remains red?
  • ronp_sa Nov 25, 2008
    Okay. I guess I paid $9.99 to be directed to a trained service person. Actually, I knew to do that if it wasn't something easily fixed.
  • 599 Answers
Yes.. red light still on indicates you have a blockage or filter installed improperly
Posted on Nov 24, 2008
    Sergeant:
  • 291 Answers
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
    Sergeant:
  • 276 Answers
There is some blockage in the dispenser
  • smarttech Nov 24, 2008
    defrost completely for few hours if some accumulated ice is blocking the dispenser or other wise remove and clean it manually
Kitchenaid refridgerator/freezer/icemaker model KBFS5ET5500 EVERYTHING WORKS BUT THE ICE MAKER...JUST QUIT. THERE DOES NOT SEEM TO BE A SHUTOFF VALVE AT THE BACK OF THE FRIDGE. I AM LOOKING TO SEE IF THE...
Hello Raymond,
In a most of cases if the filter were clogged it would affect BOTH the icemaker and the in door water dispenser,its never a bad idea to replace espically if they is a foul odor or taste in the ice or water. The water valve on the back is going to the most likely problem if the in door dispenser works yet the icemaker does not,a lot of times when the water valve is bad when its supposed to be fully closed cutting all water flow into icemaker it stays open a wee bit allowing water to seep through it causing the hose that connects to it ,running up the back wall into the icemaker to freeze up at the top where the tube enters into the freezer,that tube needs to be thawed, and to prevent it from freezing in the future the water valve needs to be replaced.
Goodluck,i hope this helps you to fix your icemaker,
Gene
Aug 09, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
ICEMAKER HAS NO WATER IN IT AND ICE STRIPPER NOT MOVING BUT WATER DISPENSER WORKS KITCHENAID SUPERBA MODEL #KSCS23INBL00 SIDE BY SIDE WITH ICE AND WATER DISPENSER IN DOOR
First check to make sure the icemaker is on. Most icemakers have what looks like a wire that extends to the right. Down is on, up is off. If yours does not have this, there might be an on off switch on the icemaker itself. If the wire (bale) is on, or the switch is on, then the icemaker is defective, unless the freezer is too warm. Icemakers have a thermostat in them that will not let them operate if the freezer is too warm. Sometimes that thermostat will not activate until the freezer is 15 degrees.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kscs25fkss00 superba - water not flowing to icemaker but water dispenser works - there is not ice blocking line/tray
Most times that is caused by the dual water control valve on rear of the refrigerator. You can test the ice maker by filling with water and letting it freeze. If the ice drops then the valve is the problem. If the ice does not drop then the ice maker is were the problem is, Thanks, Sea Breeze
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
ED25PQ quit making ice. Water dispenser still working
Pour about 1/2 cup of water into icemaker . If it harvests(dumps) then problem is the water valve.....if not , then icemaker is the problem .
Jun 26, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Sep 17, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
Jan 07, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
122 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
