What do they mean when they ask for your router name are they looking for my network name and when the ask for a password are they talking aboutmy security key or my password
  • 152 Answers
By router name they are asking about the router model number not the network name... password is the password of the user account provided for accessing the router...
Posted on Nov 24, 2008
I reset linksys, and lost my network name
You will have to setup the router from scratch. Plug a computer in and in your web browser type 192.168.1.1 when it asks for a user name put admin and no password and it will let you in to reconfigure it.
Jan 31, 2014 | Linksys Wireless-G Broadband Router
How to change wifi name in router
The wifi name you are referring to is called SSID, service set identifier. You can change that by logging onto your routers Web based utility. Open your web browser and type in 192.168.0.1 and it will ask you for a user name and password. If you keep the default user name and password the user name should be admin and the password is blank, meaning there is no password set up. After logging on, click on top tab "Setup" and on the side menu "Wireless". You should be able to change the SSID by typing in a new name in the field "Wireless Network Name". Make sure you save the changes! This should then change the name.
Mar 25, 2012 | D-Link DIR-600 Router
Toshiba satellite l675d-s7049 wifi problem? akeeps disconnecting at will
Hi
If you look down to the bottom right hand side of your screen you should see something that looks like a tv screen or something that says network internet access
take your mouse over to it and click on it to open the box
If your wirless switch is enabled it should show you that you are or are not connected to any particular network or router
If your wireless switch is not enabled please look through your user manual to find which keys to use to enable it
then in that network box please look for the name of your router or network then click on it then go down to connect
If it does not connect automaticly it will ask you for a password
so then you will have to enter the password that you have given it or look at the base of the router as the password may be the one that is written on it
if it still will not connect please go back up to the network that shows the name of your router/network and go to the left side and click on manage wireless networks delete the network that has your name or routers name theen close that box
then wait a few seconds and windows should pop up a box telling you that wireless network are available please click here
so go back to the network box go up to the name of your network/router that windows have found again
click on it and go down again to click connect and once again if it does not connect within a few mins you may have to enter the password that either you gave it or the no
written on the base of the router
if this does not work then you may have to reset your router
to do this you must use a ethernet cable plugged into the router and your laptop
then hopefully you will have a router user book to tell you what ip you need to type into your browser to enter the router to reset it
some router ip address are 192.168.2.1 or 192.168.1.1
if you cannot find the ip address of the router can you ask a friend to look it up on their internet
hope this has helped you
many thanks for using fixya
and we hope fixya has fixed it for yeh
Jul 19, 2011 | Toshiba Satellite L675DS7049 Laptop...
Hot to secure my router from my neighbors using them. thanks
click this link to open the router login http://192.168.1.1/
When asked for username use admin and password leave it empty
then goto
SETUP -> WIRELESS SETUP -> MANUAL WIRELESS CONNECTION SETUP -> WIRELESS SECURITY MODE and select "Enable WPA > WPA -> WPA Key -> create your own password and save now if you want to access the Wireless connection you will have to enter the WPA key you just created.
Apr 11, 2011 | D-Link DIR-600 Router
My husband bought a dlink router (it says dgl-4500 on it) and i cant figure out how to use it to get wireless internet for my new laptop....i have three "codes" he wrote down- a "router pass", a "network...
Router password is the password to access the router settings.
SSID is the network name. When you try to connect to the wireless network on your laptop, you will see this network name.
If your network is secured network then it will ask you for the network key or the password. You need to enter the ' security key '.
Click Here for step by step by instructions
Sep 11, 2010 | D-Link DGL-4500 Wireless Router
When trying to access wireless conection signal strength is 100%, yet association fails and connection status says dissconnected. error code 011. what does this mean? how can i fix?also how do i verify...
it depends on the router you use go to start all programs under accessories look for Run, cick run then in the run window typ CMD then press enter, then in the Dos prompt type IPconfig then press enter it will show the ipaddress and default gateway ofr your router copy the default gateway type it in Interent explorer tha should open a page where your router settings are it will ask for apassword and user name which you must know to access the router settings and be able to get the network key from the router to be able to input in your computers wireless settings to gain acces to the router and wireless internet, Call your internet service provider if you can remeber having a user name and password,
for Edimax routers user name is admin password should be 1234, linksys user name admin password eitheradmin as well or leav it blank, and yeah for further info under the router there should be a sticker with the router default user name and password on it if not on the sticker call your ISP or whoever provided the router to you for the router user name and password ^_^ hope this info will be helpfull to you ^_^
Jun 05, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Need to get laptop connected to wireless connection
the wireless network is secure... you need talk to the person that set it up to get the network key
if that is not possible let me know ... there are ways around that
and after you have the key it should hook up with no problems... as long as the correct driver is installed for your wireless
robert
Dec 16, 2008 | Linksys Wireless-G WRT54G Router
Router will not reconize 3rd computer
It is possible that the router has a wireless security enabled into it. The laptop needs the security key for it to connect to the wireless network. You can check the security enabled in your router from your router's User Interface page.
To access your router's page; launch IE from a computer that is working through the router. Then on the address field, type 192.168.1.1. It will open a window asking for a username and password. The default password to get into the router's page is admin.
Then, once you're in the router's User Interface, the main page that will open is the SETUP, beside it is WIRELESS tab. Click on it, then verify the wireless network name or SSID. Whatever name configured on it, is the name the laptop should connect to.
Then, there is a subtab under the main tab WIRELESS. The sub-tab is called, Wireless Security. Click on Wireless Security tab and then look for the netwok key enabled. Take note of the key which your laptop will be neeeding.
Hope this helps!
Nov 28, 2008 | Linksys Wireless-G WRT54G Router
Wireless network
Do you remember your wireless network name and the wireless security password for your router, check if you are able view the wireless network, try connecting to it..if it asks for passworg type in your password and check if nor revert back..
Jul 17, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
David Payne
David Payne
