Question about Panasonic Panafax UF-880 Plain Paper Laser Fax
Panafax I saw that you left me a message however we have since upgraded to a new 3 in 1 machine due to the left tab being broken. Thanks anyways.
    Sergeant:
  • 284 Answers
Ok , no prob
Posted on Nov 25, 2008
FAX machine sends darkened, bad copies
NO! This is the best Fax Machine ever made ! Your scanner is dirty. You can do it yourself.
Remove 3 chrome screws on the left side cover
remove 1 chrome screw below the power cord on the back,
Pull the cover off.
Remove the green plug on the scanner carefully
Remove the 2 chrome screws. Pull the scanner out.
Clean the 2 mirrors throughly.
Reassemble.
May 19, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
Cant recieve faxes machine says check cassette? how do I do that?
remove the toner cart, cassette and rear tray and unplug the machine
set the machine on its back.
wad up a small piece of electrical tape and stick it into the black U shaped sensor on the left side.
the small tab on the end of the paper cassette is broken off, but you don't need it....just apply my fix.
Apr 13, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Message that says "recorded paper is not loaded properly"
Could be 2 things.
Take the cover off of the paper tray and reinsert the tray
The tab on the left side front of the paper tray could be broken off.
Respond and I will tell you how to fix it.
Dec 03, 2009 | Panasonic PANAFAX UF-6000 Fax
Alarm - check cassette info code 011 - what is
The tab on the base of the paper cassette is broken off.
How to cheat it:
Remove the paper cassette
remove the tray in the back
remove the toner cartridge
set the machine upright
Wad up a small piece of electrical tape and shove it into the small black u-shaped sensor on the left side bottom.
it should work OK after this.
Nov 20, 2009 | Panasonic Office Equipment & Supplies
I got Panafax UF-595 and this fax keeps saying "check cassette info code=011" and does nothing else. What am I supposed to do to make it work?
There is a small plastic tab broken off of the front of the paper cassette.
remove the rear brown tray
remove the toner
set the machine on it's back side
stick the tape in the black U-shaped photo sensor at the bottom left corner of the machine to cheat it.
Dec 10, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Error 011
Where is the broken left tab. Sometimes on that cassette the tab breaks that tells the unit that the paper cassette is installed. If this is the case then the tray has to be replaced.
Nov 06, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Sending Documents
First the battery.
Along the top edge of the operation panel you will see a blue tab. just to the left of that tab you will see another beige tab of the same size, this is the battery holder.
Open the toner door and open the feeder ...pull upwards 1 inch until it stops.
Pull the beige tab out...not the blue one.
Take the battery to radio shack or CVS Pharmacy and match it up....CR-2032.
Next step:
press the MONITOR key and listen for a dial tone.
plug a regular phone into the phone jack to check for a dial-tone.
If all else fails.
Press FUNCTION
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
press set
set
wait for the machine to initialize and reboot itself.
Oct 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
How to fix this code????
there is a little tab on the cassette that is broken. leave me a way to email or talk to you and this could be resolved
Sep 24, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Machine will not reset after toner replacement
Info code 45 really means Toner cartridge is not installed.Info code 41 is out of toner & code 43 is toner getting low. There are three connection points inside of the fax machine that tell the machine that a cartridge is installed. Open the cartridge door & remove the cartridge. Verify that the metal tabs on the right hand side above the drive gear stick out far enough to make contact with the cartridge. There should also be two wires that are located on the left hand side that also make contact with the cartridge. Try putting your used/empty cartridge in & see if your info code changes to a 41 or 43.If not, you may have a broken connection. I have found that some compatible cartridges for the panafaxes are missing metal tabs that make contact with the connectors. Compare a cartridge that worked to the one that doesn't to see if it's missing metal tabs. This is not an issue if you are using OEM. Good luck! I can be reached by email if you have any questions. bspier@carlsonsupplies.com
May 23, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-880 Plain Paper Laser Fax Logo
20 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
