Question about Lexmark X1150 All-In-One InkJet Printer
X1150: Uneven print with some words lighter second page on
Never on first page; but on all subsequent pages some lines are lighter than others with progression as pages go on
I had bought a re-inked black cartridge from Staples; although my computer said that the cartridge was full, it wasn't working; I removed and put in a regula 16 black from Staples brand and now everything is fine. Thank you
Posted on Nov 25, 2008
How to clean head HP 7260
HP Photosmart 7150 and 7260 printers
  1. Make sure plain paper is loaded into the In Tray.
  2. To perform the first level cartridge cleaning is a spit and wipe, press and hold the Power button while pressing the Cancel button twice, then release the Power button. The printer will generate a series of noises as it performs the cleaning.
  3. Print a test page from the computer.
  4. Once the cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 5.If the print quality is acceptable, disregard the subsequent steps.
  5. To perform a second level cartridge cleaning, press and hold the Power button while pressing the Cancel button twice. Release the Power button and press the Resume button. The printer will generate a series of noises as it performs the cleaning.
  6. Print a test page from the computer.
  7. Once the cartridge cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 8.If the print quality is acceptable disregard the subsequent steps.
  8. To perform a super clean, press and hold the Power button while pressing the Cancel button twice. Press the Resume button twice then release the Power button. The printer will generate a series of noises.
  9. Print a test page from the computer.
  10. Once the super clean has the completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 11. If the print quality is acceptable disregard the subsequent step.
  11. To perform a pen nozzle test, press and hold the Power button while pressing the Cancel button eight times. Press the Resume button four times then release the Power button. The printer will generate a series of noises then print a page displaying a test pattern. If there are gaps in the printouts the cartridge(s) may need to be replaced.
Jan 17, 2015 | HP PhotoSmart 7260 InkJet Printer
Print is jumpy on x1150 even after aligning
It could be that the cartridges are not seated properly in the cartridge carrier. Open the printer cover and re-seat the cartridges and make sure it is properly secured in its place. The cover latch should snap to indicate that the cartridges are locked in its place. Try to do another alignment test page again.
Print a document to verify that the problem is fixed.
Jan 25, 2012 | Lexmark X1150 All-In-One InkJet Printer
The printer is not printing all of the page. The first page usually prints nearly all of the page, subsequent pages less so. The paper is not being scrunched up, it's just not printing lines in the...
when you press ctrl+p for print there is a setting there by the bottom left which says "Print:" beside it check the check the list if it says "all pages in range"if not press it and then press the word
Nov 28, 2010 | Canon PIXMA iP1200 Photo Printer
Printer prints words on top of each other
Check to make sure that there is nothing preventing the page from being pulled into the printer. Overlapping words is often caused by the paper feed not moving quickly enough, subsequently causing words to overlap and not span the entire page.
If that doesn't work, let me know and we'll troubleshoot further.
May 15, 2009 | Lexmark Z42 InkJet Printer
The printed pages with black is light and spotty.
Try to run the "Clean Print Heads" utility. Sometimes it is called something else, but whenever your print quality degrades, this is a good program to run. If that doesn't work, then I would suggest replacing the print cartridge. Sometimes they go bad if they have not been used for a long time. Hope this helps!
Mar 13, 2009 | Epson Stylus CX3200 All-In-One InkJet...
How do I align the printer heads?
Remove ink cartridges and re insert, it should print a test page if not print a test page from the solution centre. then scan the test page. this should reallign the printer heads.
Dec 17, 2008 | HP PSC 1410 All-In-One InkJet Printer
Labels how to print
In your Word processing program (Word, Wordperfect, Writer, etc...) there should be a label module usually found in the Tools menu. From there you can set the size of your label as well as the contents or you can have the program generate a page with a table set to fit your label paper.
Oct 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
Printing from computer
check the cable connections and re-install the driver/software
go to lexmark website and get the latest driver for your operation system.
Also when you print, make sure you are printing to this printer
print from word-pad or any other program OTHER than internet.
Jan 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
