Question about Garmin StreetPilot 2610 GPS Receiver
Garmin Nuvi 760T intermittently Freezes
My Garmin map sometimes freezes, the unit is only a few weeks old and was replaced for a unit that was doing the same. I have reset the unit and updated the software as advised by Garmin but it still happened afterwards. Is there something i could be doing wrong any advice would be appeciated.
  • matt_shaw807 Nov 30, 2008
    I have a Garmin 760T Sat Nav and the mapping keeps freezing. The unit continues to voice navigate and everything else works but the mappimg diagram itself freezes. I had this problem with another unit and this was a replacement for it i cant beleive i would get another unit with the same problem and wondeed if there is something I am doing wrong.
    Thanks for the advice, however i dont have a memeory card within the unit.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Since most (if not all) of the possibilities have been forwarded, may I offer remote possibilities:
  • if used inside the vehicle and uses the cigarette lighter adapter:
  1. looses ground;
  2. faulty alternator's voltage regulator;
  3. loose/corroded contacts of the cigarette lighter adapter.
  • Others are:
  1. operated near high power RF emitting equipment such as 2way radio, even a microwave oven, communications tower, radio beacons;
  2. operated in highly magnetic areas such as a power station, wrecking places;
  3. operated in high static electricity area such as carpeted floors.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 01, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • 541 Answers
I would go on here http://www.garmin.com/garmin/cms/site/us/support/supportcontact and ring them and if have only just got you can take it back
Posted on Nov 30, 2008
  • 163 Answers
You may have recieved another bad unit, it happens more often than you would think. try replacing the unit again. if it does it again then there may be some type of interference affecting it, i.e. cell phone, vehicle computer system...
    Genius:
  • 2,120 Answers
Not your problem. Take it back and try a Nuvi 770 or 780
  • 928 Answers
From all indications it looks like its a device issue. I would suggest you wait for an updated firmware from Garmin then update to that. Report the problem with garmin and request a firmware that will fix that. The fact that 2 units experience the same problem means that its a permanent device issue that can only be solved by a firmware that fixes the specific problem which only Garmin can provide.
  • Thomas Lim
    Thomas Lim Nov 30, 2008
    There are no other options that can work as it looks like its a factory problem with the unit. You can request for a model exchange for a replacement with Garmin. thats an option that you can take.
    Sergeant:
  • 237 Answers
You need to reset the nuvi, follow these steps:
Turn the nuvi off and on again. If this does not help, slide the POWER key to the left and hold for 8 seconds. Turn the nuvi back on. The nuvi should operate normally.
  • zabrina liang Nov 30, 2008
    PS, the nuvi received a new update in October of 2008. If you have not downloaded this, you need to do so. Follow this link:
    https://buy.garmin.com/shop/store/downlo...
    The Garmin has an internal memory, call Garmin to see if you can have that upgraded. Usually, when a computer freezes up, one of the reaons is lack of memory to support the data. Otherwise, return your Garmin for a different model. If you want the same model, ask and make sure you be replaced with a brand new one, not a refurbished model. Those are prone to have little bugs and defective areas in them.
    Genius:
  • 1,011 Answers
Sir,
Tried some other batteries. Try to change the battery.
Typical battery life of 4 AA alkaline batteries in the Garmin 12 is 24 hours. Weather below
freezing quickly drains alkaline batteries, so lithium batteries are recommended for cold
conditions. All Garmin 12 series contain an interior backup battery to preserve data when the four AA batteries are
removed. This backup battery has a 3 month lifespan on its own, but is rechargeable from the main batteries, so
keep AA batteries installed in the Garmin at all times.
thanks
good luck
    Genius:
  • 1,239 Answers
Hi it will hapen only for 2 reasons 1.low memory power 2.network operator settings/or slow gprs
so please check it....thank u.......
  • ABHISHEK.C
    ABHISHEK.C Nov 30, 2008
    if it doesnt have memory card..then i think you have firmware to your phone.......install it and see the changes
  • 4,806 Answers
If this is the second unit that you have had replaced tells me that the problem could be generic with that model GPS.
Because of this i would take it back, get a refund and go buy a Tomtom instead
king regards
  • 4 more comments
  • Lee Hodgson
    Lee Hodgson Nov 30, 2008
    yes you do get alot of units that develop the same problems, you are doing nothing wrong at all, the fact that you don't have a memory card is nothing to do with the problem.
    Try perform a reset of the unit, there could be a glitch in the firmware
    regards
  • Lee Hodgson
    Garmin diagnostics screen / reset
    When you're at the main screen, hold your finger on the time in the
    upper right corner for more than 5 seconds, and you'll get to an info
    screen, and back/next buttons lower right of screen.
    There's some sound diagnostics, and screen tests, and lots of info
    pages - including one with some battery status/statistics. To get out
    of the diagnostic mode, power cycle your unit...and when you do this,
    it will take some time to lock on to satellites.
    regards
  • Lee Hodgson
    hope this helps
    regards
  • Lee Hodgson
    If you have performed reset and the problem still persists its obvious that there is a major fault with the unit, like i said you have done nothing wrong and the unit may have to be replaced
  • Lee Hodgson
    i may have the soloution you need
  • Lee Hodgson
    Lee Hodgson Dec 01, 2008
    Hi again Matt, go here and reinstall the units software:
    http://www8.garmin.com/support/download....
    hope this one helps you
    regards
    Sergeant:
  • 217 Answers
Reset the device and try if it still has same problem then the faulty memory may be causing this.replace the memory card to solve this problem
    Genius:
  • 3,422 Answers
HI,
There are only to home remedies to fix this problem.One is a hard reset which you have alreasy tried and the other is to update the firmware which you have already tried.
You will have to get this repair because it is a hardware issue.
  • 10,594 Answers
I think, some times unit is not getting proper GPS signal through its internal antenna so signal processing got freezes. Please check GPS
signal strength bar (on top left of screen) is ok. If its not full, then use external antenna.
  • Shahid Electronics
    Shahid Electronics Nov 30, 2008
    Now unit is exchanged but problem is same, so check common things now like memory card etc.
    Genius:
  • 1,550 Answers
Try charging the gps by an external charger through the USB
  • SAM ANDERSON Nov 30, 2008
    You have mentioned that it is freezing sometimes may be its due to weak signal at that particular location . Your antenna connection might be loose or it might have been damaged . Try with external antenna if this works then you need to replace internal antenna .
  • 19,396 Answers
If you are using same memory card, it can be a faulty memory card.
Try a replacement memory card.
If you are connecting the module to a different device, then the connection cable or the other device may be the problem.
  • Ginko
    Ginko Nov 30, 2008
    If you are installing additional software, or always the same maps, and using the same memory card, then one of them can be the problem.
    Reset the nuvi to factory settings following the procedure on the user manual , and see if you can get rid of the problem.
    Reset the unit, holding the power button to the left for 10 seconds then let go of the switch to restart the unit.
    there are many factory problems with 760, see here:nuvi 760 - won't turn on - gps Discussion Forum
    if the reset does not work call them back.
    Top Expert:
  • Garmin Master
  • 77,499 Answers
Since there is zero you can do this fix this send it back, this is a program fault, I know I have the same Garmin.
  • yadayada
    yadayada Dec 01, 2008
    SEND IT BACK, THERE IS A FAULT IN THE PROGRAM, GARMIN WILL FIX IT FOR FREE, THEY ARE VERY GOOD ABOUT THESE KINDS OF ISSUES, AS A CONSUMER THERE IS NOTHING YOU CAN DO TO CORRECT THIS PROBLEM, JUDGING FROM ALL THE THANKS FOR TRYING RATINGS YOU DON'T WANT TO HEAR THIS, BUT NEVER THE LESS IT IS THE ONLY SOLUTION.
My nuvie 660 screen freezes, sometimes it works on startup, sometimes not. When it works on start up, it freezes as soon as I start to move
If you press the on/off power switch and can toggle the screen, then he unit isn't locked up at all. The touchscreen is either intermittent or has failed and needs to be replaced. More info can be found here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Apr 30, 2011 | Garmin Nuvi 660 GPS Receiver
My garmin turns on but freezes when loading maps. I tryed to reset but did nothing.sometimes it will stay froze and sometimes it will turn itself off.serial #12p238176
Clear all ur installed apps/data/music/pictures first. Turn the unit off and then on. while on, reset it again. turn it on again and now connect it ur PC to load additional maps and see if it helps.
thanks
Aug 11, 2010 | Garmin Nuvi 660 GPS Receiver
Unit freezes at the loading maps stage
Yes! Yes! The exact same thing is happening to my nuvi 1300 right now one month after yours. What did you figure out? Can someone help? I've also tried to do the clear the device by pushing the right hand corner of the screen while powering on and I do not get any sort of 'would you like to clear everything?' message that I'm suppose to get. I'm going to check into battery recall that I heard about, but I don't think it's for the Nuvi 1300. Someone help! A :)
Jul 26, 2010 | Garmin GPS
It will not power on. The name garmin is on the screen with a black background.what could the problem be?
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 13, 2010 | Garmin nuvi 1300 Car GPS Receiver
Upon turning my Garmin Nuvi 1300 on it sticks on the screen that says "GARMIN".......Loading Maps. It never goes past this screen. I have had this unit since the end of December. It is fully charged and I...
I hope that helps.
Apr 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi 1340 freezes on start up
If your nuvi series device is freezing on the map screen but still providing voice prompts there are two steps you can try to resolve the issue including updating the software using WebUpdater* and performing a master reset.
To download WebUpdater and update the software:
  1. Go to http://www8.garmin.com/products/webupdater/howtoinstall.jsp
  2. Follow the on screen instructions.
To perform a master reset on your nuvi series device: CLICK HERE
Warning: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 18, 2010 | Garmin nuvi 1300 Car GPS Receiver
Sometimes the screen goes blank and after 5 -10 min will let you turn the unit back on
I hope that helps.
Feb 21, 2010 | Garmin nuvi 1300 Car GPS Receiver
My NUVI 1300 has frozen at the "Loading Maps" screen. It also freezes when connecting to my laptop so I cannot perform an update. I've tried touching the bottom right while powering up and have erased...
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Feb 12, 2010 | Garmin nuvi 1300 Car GPS Receiver
I just got a Garmin nuvi 1300 for Christmas and it has worked just fine for almost 2 weeks. Then yesterday, out of the blue, it shut off for a few hours and would not turn back on. It did the same thing...
I hope that helps.
Jan 07, 2010 | Garmin nuvi 1300 Car GPS Receiver
My Garmin sometimes freezes
Try update the unit with the latest firmware by using WebUpdater from Garmin.
Oct 28, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin StreetPilot 2610 GPS Receiver Logo
148 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
