Question about Canon PIXMA MX300 All-in-One Printer
Canon mx300 printer dont know how to enlarge/decrease photostat
How do i change margins or increase/decrease size of print
  • ladorado2000 Jan 03, 2009
    Printer is printing smaller size fonts than what is on computer. How do I make the size of print larger on the printer?
  • Anonymous Mar 12, 2014
    how do you enlarge the print size on a dell all in one a24 printer
Had several other problems with my new canon mx-300 printer. trouble with word perfect and scanner Phoned Canon tech who brushed me off saying trouble was with my driver and not compatible with my computer. Returning it to the store tomorrow and going to pick up a HP
printer somewhere else..
Posted on Nov 25, 2008
IR3300 copier drivers
You might want to post this question in a different section. This is the computer section.
Jun 28, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Left margin cuts off
Try changing the left margin size in the page setup. Decrease the left margin size.
You could also try printing in Landscape instead of Portrait just to see if it captures the left margin.
May 31, 2012 | Samsung CLX-3175FW Multifunction Laser...
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Aug 07, 2010 | HP Officejet 5610 All-In-One InkJet...
How do I set photosmart B209 to enlarge copies?
http://h10032.www1.hp.com/ctg/Manual/c01796502.pdf
Pg 57 Item c, where is says touch size, instead of fit to page, you should have other options to increase or decrease the size.
Another option it to scan the item to the computer then print and enlarge during the print process
Mar 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
Canon MP480 printer prints enlarged text and shifts page margin
hi. have you tried print from other pc. ? if still the same issue maybe is a internal problem with your printer
Apr 30, 2017 | Canon MP140 PHOTO AIO All-In-One InkJet...
How can I make the printing larger when I print something on the printer?
Hi ewcah,
I assume you have installed your printer according to the manufacturer's instruction manual.
I also assume that you haveread but misunderstood the "tutorial and help" buttons on the toolbar.
There are many ways to enlarge printed output:
Most software provides access to print fonts (how the characters appear) and font size both of which will be in the toolbar for the software, This route is easiest because you can use the page preview button to see what the result will look like.
In the drop down FILE menu, will be a section about printing. You can set up the page (margin sizes, headers etc.), preview how the page will look, and print it.
In the preview section, you can often increase and decrease the percentage size of the contents to fit the page.
Depending on your printer, the print button often takes you to the printer control page where you can specify copy numbers, margins etc. There are Option and Properties buttons on some print control pages which allow you to make many more print output changes.
I hope this helps you get started,
jenni
Sep 09, 2009 | Dell 924 All-in-One InkJet Printer
How do i increase print size
Your font and font size are set up in word. Depinding what version of word you are useing as to where this option is. If you look at the top of word screen, you should see a box that lists the font and font size. If you can't find it, go to help and type change font size and it will walk you through how to change your font size.
Mar 05, 2009 | Brother MFC-5840CN All-In-One InkJet...
Save the picture to your computer, go to paint, select it, enlarge it, and print it. If you found this helpful, post a solution or something and say this was helpful.
Thx.
Feb 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MX300 All-in-One Printer Logo
196 people viewed this question
old marine
old marine
