Question about Dacor Preference SGM466 Gas Cooktop
No gas to hobs
I have a fitted Hygena oven with Hygena gas hobs. My ignition now doesn't work and two hobs don't have gas going to them anymore plus the dials are stiff to turn around. Think it needs a majorly good clean, but can I push off the hob top to clean it?? Think I can prise it with a lot of hard effort, but will this break it?? Help as need all four hobs for christmas!!
  • thibathiba Apr 28, 2009
    Fisrt the gas was licking, solved the problem, but gas does not pass through to the burners, how should I solve the problem. Eunice, Lesotho
    Novelist:
  • 222 Answers
Use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Posted on Dec 02, 2008
Cleaned my gas hob but now when you turn the gas on the automatic ignition doesn't switch on. Model candy pl 40 ax. I have checked the fuse on the plug but that's ok is there another fuse I should kno
Is it pluged in. Check to see if the plug Still works behind the stove It might be on a GFI plug needs to be reset somewhere along the backsplash counter
Jul 19, 2013 | Cooktops
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Trying to get hold of a fitting instruction leaflet plus list of spare parts for a gas hob code no. E4NE T2484SOEU/01
Why do you need a fitting manual ? Any competent gas engineer should know the contents of BS6172 / BS6891 which both apply to the fitting of domestic gas cookers / hobs. What spares do you need. You can get a spares inventory from Neff. Ensure that it is the correct appliance for the fuel gas you are connecting to. The jet sizes for LPG & Natural Gas are very different.
Apr 16, 2009 | Neff T2346 Gas Cooktop
Creda gas hob now keeps ignighting
the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
Dec 23, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Converting gas hob to electric hob
If you are in the USA most codes require a seperate circuit for the oven and the cooktop. Most cooktops require 30 amps and at least #10 wire.
Jun 09, 2008 | Cooktops
Burner/Flame
Hiya .. this could be due to a number of problems...... has the burner ever worked correctly?
Is the behaviour with only one ring?
1. If not... then it could be that the pipework to the hob itself has not been recuced sufficiently enough in pipe diameter to the regulator far enough back ...
2.The regulator is faulty... in which case it can be replaced... however consider the cost of a new regulator and labour to fix it .. against the cost of a whole new hob... which should include a regulator. Is the hob still under warranty... if so use that .. but you will normally have to provide some proof it has been fitted by someone suitably qualified.
3.the regulator may never have been fitted, which is dangerous and bad practice.
Either of these scenarios... please ensure that you use a suitably qualified gas engineeer... I dont wish to be alarmist... but gas leaks and faulty gas appliances do cause unnecessary deaths...and is a silent killer.
Regards Faggly
Mar 26, 2008 | Maytag MGC5430 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Dacor Preference SGM466 Gas Cooktop Logo
717 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
