Question about Epson Stylus C42UX InkJet Printer
My epson stylus C42UX printer cartridge is getting stuck
Once turned on and as it is getting set to print the cartridge gets stuck on the right side (my right side while facing it) and then will continously click in place till it stops. Once it stops the red light on top for ink or paper will turn on.
  • Anonymous Jan 16, 2009
    printer not used for long time , think nozzles clogged . only red printing would like to try head clean annd new black cartridge but cant gewt cartridges to stop at accessable possition HELP not very confident of computer use im a dummy.
  • anguisette Mar 12, 2009
    exactly the same proble, moving  "the plastic arm" doesnt help though! :(
  • 353 Answers
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right hand end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below), or some other mechanism fault.
If you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above! If you want to have a go at doing this yourself, please report back for help on this.
If neither of these apply, please report back for further help.
Posted on Feb 10, 2009
Epson stylus c42ux how do I put in new ink? I can't get to the print cartridges
Power up the printer and open the lid. The print head should come to the center. When you close the lid, it will go back to it's park position. Don't pull it over with the power off.
Jun 01, 2011 | Epson Stylus C42UX InkJet Printer
Our printers epson c42ux red light is on stand still
A permanently on red light can mean several things. If the green light is also ON, it means that you heve no paper loaded, an empty or faulty ink cartridge, or a jammed paper feed. I presume you have loaded paper. You say you have changed the ink cartridges. Note that BOTH cartridges must have ink for the printer to work. The simplest way to check this, or to check for a faulty cartridge, is to try another new set of cartridges - compatible cartridges are very cheap on EBay - about £3 a set in the UK.
To check for jammed paper, remove the paper from the sheet feeder and look carefully inside it, and inside the printer (lift the lid) for scraps of jammed paper. Remove any you see. Press the ink/paper feed button and see if it goes through a paper feed cycle. Reinsert the paper and try it again. If it works, turn the printer off and on again, and it should now be OK.
If the green light is OFF, it means you have a Carriage problem, i.e. something is fouling the print head when it tries to go from side to side. Check this with manual movement. Turn the printer off. After a few seconds, turn it back on again. As soon as the print head moves, pull the power cord out of the back of the printer. You should now be able to move the print head across to the left side (gently!) by hand, then move it back to the right and see if it will go fully into its parking bay at the right hand end. You should be able to tell if someting is hindering its movement anywhere.
Please report back with a new comment if none of this solves the problem.
May 31, 2009 | Epson Stylus C42UX InkJet Printer
Epson c42ux cartidge stuck, won't feed
Hi Sunny Shine
It's very difficult to help you if you don't respond to our questions! If you continue to maintain a mysterious silence, we will presume you no longer have a problem - Problem Solved!
Feb 18, 2009 | Epson Stylus C42UX InkJet Printer
Replace ink cartridge
The Reference Manual provides clear instructions on this in the "How to" section. If you don't have a copy, download it from:
http://esupport.epson-europe.com/FileDetails.aspx?lng=en-GB&data=FGQ8MBMpKlt3LcQmNeQVzwoYgQ5dO95G&id=8985
If I can clarify anything, report back
Dec 01, 2008 | Epson Stylus C42UX InkJet Printer
Lost software having trouble installing
You can download the drivers for that printer here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14403&prodoid=21643927&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=14&y=14
The driver is what enables your computer and printer to communicate....that should get you printing again!
Oct 05, 2008 | Epson Stylus C42UX InkJet Printer
C42UX problem
An unknown printer error has occurred. Turn the printer off, disconnect the interface cable and turn the printer back on. If error disappears, turn the printer off, reconnect the interface cable and turn the printer back on. If error continues then printer needs service. If printer returns to normal the issue is resolved.
Jun 09, 2008 | Epson Stylus C42UX InkJet Printer
Printer cartridges
Hi:
I solved this problem; there was a white plastic "piece" stuck upwards and all I did was push it back down. Now the cartridges are able to go all the way to the right and the printer is working properly. Looks like I need to replace the cartridges now, that's all.
Thanks.
Lori
Feb 18, 2008 | Epson Stylus C42UX InkJet Printer
EPSON STYLUS C42UX PRINTER.
I have had the same problem, my solution was taking a hammer to the stupid thing and buying a lexmark!
Dec 10, 2007 | Epson Stylus C42UX InkJet Printer
Epson Stylus C42UX InkJet Printer Logo
675 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
