Magnavox MWC24T5A I have this combo TV vcr/DVD that started shutting itself down right after you push the power button to turn it on. I found one other person that posted the same problem and no one has responded. I do have an electronics degree but don't know much about TV repair....except the tube voltage dangers,etc. When I push the power on button, the unit turns on for about 3 seconds and then shuts down. THere is no DVD or VCR tape in the drives. Thanks Larry
  • Larry Foster Nov 24, 2008
    Yes, This information is helpful. Thanks very much Bill.
  • Anonymous Apr 26, 2009
    I have the same problem. Where is the IR diode located, what does it look like and what do i ask for at Radio Shack?
  • 934 Answers
It is most likely a bad IR diode underneath the prisim in the VCR, common failure for those combination units. I have used a simple generic diode from Radio Shack or you can spend a little more and get the politically correct part from almost any electronics vendor like Vance Baldwin ot Tritronics.
Be observant when installing these they are polorized and go in only one direction. Getting one in reverse will burn up the new diode instantly.
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
Posted on Nov 24, 2008
Magnavox DVD eject button fell in TV
Take a close look where the plastic button was--it if there would engage a tiny round black rubber like button---using a pencil eraser see if you can gently push the button.
Jun 13, 2012 | Philips Magnavox 20MC4204 20 in. TV/DVD...
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
Feb 12, 2011 | One For All URC-4021 Remote Control
My Magnavox MWR20V6 DVD VCR Combo shuts down, after 5-10 seconds, following start-up (on/standby button). I saw "E1(rear)," on the TV screen, just before it shut down the last time. I suspect...
Before anything, I would attempt to see what the E1 code signifies. But usually when those things just shut themselves down it is because of a serious problem in the power supply. I think it is time to go shopping.
Sep 16, 2017 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I don't have the remote for my tv and need to get into the menu to turn on captions, how can I do that? have a Magnavox 24'' TV/DVD/VCR Combo MWC24T5
On some sets you can push the Up and Down channel buttons at the same time.
You might also buy a new remote:
Jun 29, 2010 | Televison & Video
May Magnavox MWC24T5B tv/vcr/dvd combo will not stay on.
I've found the center LED in the VHS player faulty with those symptoms. Change it you'll be fine. Larry
Jun 17, 2009 | Philips Televison & Video
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox combo vcr dvd
unfortunately the tape clamp sensor is broken or worn, or could have dust or dirt obstructing it and they don't have parts for these anymore, the tape clamp sensor is like a tiny white plastic sensor only a few millimeters in size with a red eye inside the edge of the tape carriage, and needs possible cleaning, it could be something as simple as dirt inside the mechanism over the sensors, the Tv will power down when the error occurs not much you can do if a clean or high output air blow of the components don't do the trick. sometimes dirt in the circuit can cause it to do that too, surprised it lasted this long actually they were great for the bedroom, i had one ages ago they are available on ebay for about $100 or under now ...Sorry i couldn't be of more may get away with disconnecting the white feed ribbon cable that powers the tape cartridge and just use it as a DVD and Tv, that should stop the error.
Apr 26, 2017 | Televison & Video
Im thinking that maybe you a have a timer recording set. The whole unit wont function at all if you turn it on via power button (remote or unit). There should be a button at the top of the remote called 'timer set' pressing this will disable that mode and allow complete use of everything. but make sure u press timer set again when powering down, otherwise simply turning off the machine will leave the timer recording disabled.
Oct 17, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
358 people viewed this question
Top Televison & Video Experts
