Question about Acer Aspire 8920-6671 Notebook
White area in LCD screen with colored vertical lines
Hi, I have an Acer 8920G laptop, that I have only had for about three months, I bought it at the end of August. About a month ago I switched the laptop, after a completely normal session the day before, and the about an 8th of the right hand side of the screen was all white with a few vertical colored lines in it and nothing else. This never changes within a session of having the laptop on, but it does vary between sessions. For a while I was switching it on and it had a thing white line about four fifths of the way along the screen and then a normal image on the other side of the line, where previously it had been all white.
I originally though that the display potential of that side of the screen was lost, but after seeing that it does have the potential to display an image it has confused me.
At the moment the white area has increased to take up about a quarter of the screen, and has been fluxuating between these 3 states.
Any help would be greatly appreciated as I love my Acer laptop apart from this really annoying problem.
  • b3nfather Nov 30, 2008
    I'm thinking it may be a problem with the cable that connects the cable to the LCD screen. Does anybody have an idea how to be able to see if this cable is pushed in properly? It looks like it is located on the left side when I unscrew and uncover the cylinder hinge area where the laptop meets the LCD screen, but I can't see any connection from here.
  • 538 Answers
LCD needs to be replaced.
Common problemcalled "Tab separation".
Posted on Mar 20, 2009
Recently I turned on my TV and I have vertical white area with some lines that are colored on the left side of the screen. The rest of the screen looks fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 04, 2015 | Sharp Televison & Video
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
Lcd screen has lines in the middle area (3" wide
Laptop screen display problems occur for many different reasons. Some issues need professional attention, but others can be repaired by the owner. A screen that displays vertical lines often means that there is a problem with the video cable connection to the LCD screen, or the cable itself. In order to repair this problem, the display screen must be disassembled. If you feel confident that this task is within your realm of expertise, follow the steps below to remove your laptop's LCD panel and fix the vertical line problem on your laptop screen.
1. Remove the rubber seals covering the screws on your screen's outer frame using a flat-head screwdriver. Remove the screws, then carefully pry the frame from the screen using your fingers. Release the plastic latches holding the framing in place, then remove.
2. Remove the screws holding the screen to the support brackets. You will see the video cable, which is attached to the back of the LCD screen. Try unplugging and reconnecting this cable, making sure that it is seated properly. If the problem was the connection, this may solve the vertical line issue.
3. Turn on the laptop. Move the video cable around a bit, without moving or touching the screen. Check the screen to see if the display image changes at all. If it does, the problem may be with the cable itself.
4. Move the laptop screen around to see if this affects the display. If so, the problem is most likely with the LCD screen itself, not the video cable. Replacing the screen will be necessary.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | Acer Computers & Internet
Black shadow on screentnfmurtagh
my new one month acer aspire laptop lcd screen become white vertical flash lines
Jun 15, 2011 | Philips 32PF5531D 32 in. LCD Television
How can I remove the thin vertical bluish line on the left side of my laptop monitor? My pc is Aspire 4738ZG and just bought this 4mos. ago. The vertical line just appears suddenly on my laptop screen and...
If this line is present on every window you open, it may be a problem with the LCD itself. As it is new and I presume still under warranty, I recommend you to take it back to the after sales to get it checked.
By experience, I can tell that in most cases, this type of line on the monitor comes from a defective LCD monitor, and if it is the case, it should deteriorate with time.
May 10, 2011 | Acer Computers & Internet
A vertical white line appears on my screen
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical white line. Usually screen replacement is the only answer to fix it.
Feb 17, 2011 | Acer Aspire 4315 Notebook
White screen on Acer Travelmate 7720
most likely you have a faulty LCD screen, the only option u have is to replaced it or u can use a external LCD screen to act as screen for your laptop. you'll be needing a VGA cable to connect your laptop to any LCD screen available.
Dec 16, 2009 | Acer Aspire 7720 Notebook
HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Dec 08, 2009 | HP Pavilion zd8000 Notebook
this is a lcd or lcd cable problem
Feb 26, 2008 | Acer Aspire 9502WSMi (AS9502WSMI) PC...
Black screen on Acer 5100, but will work with external monitor
It sounds like the control board or cable for the LCD may be damaged. If you're still under warranty, you'll need to send it back to Acer to be repaired.
Feb 13, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 8920-6671 Notebook Logo
595 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
