Question about Kenmore 60172 Electric Commercial Dryer
Clothes don't dry but dryer gets hot
I have taken off the back and thoroughly cleaned out the vent, the fan, and the vent hose to the house. It still takes 2 rounds to dry a load of laundry. The dryer gets hot. It is a Kenmore 70 series electric dryer. What else could be wrong?
    Genius:
  • 1,028 Answers
Ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Posted on Nov 25, 2008
My dryer runs and heats up but doesn't dry the clothes. i noticed some dampness on dryer door when i open it. the clothes circulate but don't fully dry. i noticed the dryer is heated and light is...
Hi mandolins23...
Sounds like your venting system is plugging up, try these suggestions below...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Aug 30, 2011 | Kenmore 600 7962 Dryer
Dryer not drying in alloted time
there is a thermostat. it usually is located on the heating element housing
May 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My dryer is saying to check filter but the fileter is clean, the vent hose in the back is clear and it is still not drying the clothes. The dryer is putting out heat, but the clothes are still wet after a...
There is a restriction in the dryer venting system. If the moisture is not removed from the dryer thru the moisture vent then the clothes will get hot but not dry. You will need to remove the vent hose at the back of the dryer and look inside the vent pipe and see if it is restricted with lint. You might need to reach up inside the vent with your hand and pull out the lint. Also some of the newer dryers have a fan assisted venting system and if the fan stops working that can cause this issue.
Dec 07, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Dryer is hot, but not drying clothes. taking a
You have a plugged or resrticted exhaust flow. Remove the dryer and clean out the vent hose from the dryer all the way out of the house.
Jun 30, 2009 | Whirlpool Dryers
Doesn't Dry Thoroughly
if you have not already you need to clean out your vent hose. if you have a bunch of lint build up in the hose or in the blower wheel of the dryer it won't move air through the dryer that needed to dry.
Jun 24, 2009 | Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer still gets warm but not as hot as it used to. Takes forever to dry clothes. Clothes used to come out really warm yo hot and dry butno more.
sounds like an airflow problem. disconnect the vent behind the machine and clean it out thoroughly. it might be kinked behind the machine, be careful when you push it back to the wall as to not kink the vent hose. if possible use a straight smooth metal duct to exhaust the air to the outside of your home.
Mar 10, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Kenmore 60172 Electric Commercial Dryer Logo
248 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
