Question about Rollei Cameras
Camera ran out of battery,whilst zoom lense out.Replaced with new batteries but now when i turn the camera on it bleeps for about 3 seconds and then goes off.I cant even get it to stay on long enough to bring zoom back.Please help as i really need to get this fixed for xmas.
Some batteries (especially the lower mAh rechargables) don't seem to have enough power. Try putting in a couple of brand-new (non-rechargeable) Duracells, and see if that helps.
Posted on Jan 22, 2009
Kodak
Call Kodak at this #.... 1-800-822-1414
Regards,
Dennis
Aug 28, 2014 | Kodak PIXPRO FZ41 Compact Digital Camera -...
Nixon coolpix l810 will not turn on just replaced batteries wondering if batteries are the issue
When switching it on you have to be sure you remove the lens cap beforehand as an error message will be displayed. If you do not see an error message and the cap is off, you might not have the updated firmware version 1.1. Nikon's website states:
"When some new AA lithium batteries were inserted in the camera and the camera was turned on, the camera sometimes failed to function. This issue has been resolved."
To download go to:
http://support.nikonusa.com/app/answers/detail/a_id/18049
Jan 08, 2013 | Nikon COOLPIX L810
If i turn on the camera the lens gets stuck halfway then bleeps and turns off? Help I can't afford a new camera or an expensive repair bill!
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Apr 22, 2010 | Samsung S760 Digital Camera
S800 powers on and goes off, lens stuck zoomed out.
i had the same problem with my samsung s800 camera (from new!!!) draining batteries quickly and then being left with the lense out, i took the camera back to where i got it from (argos) and after being asked if i was sure i was putting charged batteries in they sent it away for repair and it turned out that the lense mechanism was broken, i think they charged me £10 to get it fixed but i have had no problems since then.
Dec 10, 2008 | Samsung Digimax S800 Digital Camera
Samsung s1030 will not retract lense and bleeps 3 times then no response - batteries are fully charged
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work.
Try this alternate solution (got information from HP )
  • Turn off the camera, if possible.
  • If an SD memory card is installed, remove the card.
  • Remove power from the camera as described below:
  1. If you are using only batteries for power, open the battery/memory card door and remove both batteries.
  2. If you are using only the AC power adapter, disconnect it from the camera.
  3. If you are using both batteries and the AC power adapter, remove both batteries and the power adapter.
  • Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
  • Turn the camera on and off. If the lens does not retract correctly or the camera does not turn on,
You need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Dec 09, 2008 | Samsung Cameras
Low battery display
i had a similar problem...my lense woudnt go back in either, but it kept saying low battery and bleeping. I realised that my lense was stuck skwint, and that was what was causing the problem, once i straigtend up my lense it folded bak into the camera and worked fine wen i turned my camera on :D
May 06, 2008 | Samsung Digimax D53 Digital Camera
My batteries died in my pink i733 and when it shut down the "zoom lense" did not recede. i put fresh batteries in it but all that happens is that the green light flashes. it wont come on or...
This can sometimes be fixed if you remove the batteries over night and allow the camera to sit and discharge it should correct this problem. hope this helps.
Mar 28, 2008 | Polaroid i733LP Digital Camera
Zoom lense going in and out when turned on
Try taking the batteries out and plugging it in. If it powers on, put fresh batteries in and try again off the AC. Once it's powered up from the AC, unplug it and see if it stays on. If it does, try restarting it. Good luck.
Aug 18, 2007 | Olympus FE-110 Digital Camera
Power zoom not working
If you dont have rechargable NiMH batteries get these first. Alkalines just dont have the power anymore these newer devices need. If you do have NiMH and yours still having problems try and tap on the lenses as you power it on. As the motors that drive the autofocus and the lens mechanisim wear they draw more current. When this happens the unit draws more power then the batteries can supply and you run into problems. If your camera has a battery pack you may need a new one. They test them new and everything is good on paper but after some use things change.
Apr 24, 2006 | Olympus Camedia C-750 Ultra Zoom Digital...
Cameras Logo
78 people viewed this question
Top Rollei Cameras Experts
Jax Planet
Jax Planet
james laughton
james laughton
Are you a Rollei Camera Expert? Answer questions, earn points and help others
