EMmachine Tower 600is power shut down after being on for 1 minute
    Novelist:
    Scholar:
  • 85 Answers
The CPU is probably overheating because of dust build up between the fan and the heatsink
Just unplug the computer and open the case then very carefully unscrew the fan from the heatsink but do NOT remove the heatsink if you do not have to especially if it has an AMD cpu since AMD cpu’s burn up quickly if the heatsink is not perfectly installed or if the heat transfer grease comes off when removing heatsink so it is best to just leave the heatsink clamped down and just unscrew the fan
Once fan is removed you will notice a thick layer of dust build up that you could not see with the fan on and so just carefully remove the dust with an old tooth brush or something like that (it does not have to be spotless or perfect just as long as the main thick parts that were preventing the air from the fan from hitting the metal heatsink are gone then carefully put the fan back on the heatsink and now that the barrier of dust is removed the air will hit the metal like it is supposed to and no more overheat
You want to do this as soon as possible since it doesn’t take very many times with AMD CPU'S for them to overheat permanently and never work again (ive seen them burn up in just a few times).
p4 CPU same thing dust needs to be removed but be very careful when removing and replacing the fan and heatsink so that you do not accidentally break off one of the 4 plastic clips that hold it on because there will be no way to hold it on properly if even just one clip breaks and you will then need to go out and probably buy a different type of heatsink for it that screws on from the bottom of the motherboard and that can be quite a hassle to install since board would have to come completely out of the case to do so.
Once you are completely finished and power up the computer go into the system bios and check the hardware monitor to see the temp of your CPU if it says 70c or higher after just barley turning it on then maybe there is still dirt to clean off or the fan might not be spinning.
any temp lower than that is fine (temps vary from different motherboards if it is down in the 40's then your good to go with no worries but being in the 50's is ok too .. if its in the 80's then just pull the power cord because that’s way to high..
temps referred to here are all in Celsius by the way
Posted on Nov 25, 2008
Why don't I have service? I have minutes and service until 3/2016.
Have you tried powering-down the phone - I mean completely shutting it off - then allowing it to sit for a few minutes before powering it on again?
Jun 18, 2014 | LG Cell Phones
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
No instructions on how to open and shut down my asus tower of my compyter.
Press the power button, usually on the front of the tower to switch it on and use the power button, lower left of desktop, to switch it off.
Dec 05, 2013 | ASUS Eee 4G Notebook
My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Jul 28, 2011 | Acer Aspire™ T180 PC Desktop
I am running winows xp my moitor is stuck in sleep mode and I can not use my keyboard
Try restarting your computer, when you have the system up check your power management features.
Hope it helps!
Feb 14, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
How do i reboot my pc
Read the Below Guide How to Reboot :-
http://www.ehow.com/how_4479754_reboot-pc.html
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 09, 2009 | Computers & Internet
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Why does my computer suddenly shut down during use?
remove the side panel and have a look if your cpu fan is turning.... you may need to blow the dust and dirt out of it as well... if the tower even feels remotely warm that's likely the issue... also check the fan on the power supply. either way it will likely need to be cleaned
Robert
Jan 13, 2009 | Computers & Internet
Power cutting out from tower. EMACHINES 550
There maybe to much dust build up on your cpu cooler that causes it to shut down to protect itself it needs clean about every 2 months or less to make it run smoothly.That is one solution the other solution is that your power supply needs to be clean also or replaced.Buy a can of air from your local computer store or walmart etc......
Jul 28, 2008 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
Computers & Internet Logo
69 people viewed this question
Alun Cox
David Payne
David Payne
