Question about West Bend 56870 Coffee Maker
Plugged hose that has the "ball in the cage"
My coffee maker was not letting water into the coffeepot from the reservoir. I took it apart and the hose with the "little ball in the plastic cage" was plugged with a tiny piece of plastic debris. I didn't remember which direction the ball part should be in the hose and which way it should be reinstalled in the base. I don't want to put it in wrong and burn up the element.
Why can you not find a replcement pot for this coffee maker
Posted on Sep 03, 2008
SOURCE:
Does the b60 have filter and were is it
The filter assembly is several inches tall, with a basket-like holder for the cartridge at its base. The unit snaps in place over the outlet in the base of the water reservoir.
Lift and remove the cover of the water reservoir, which is located on the left side of the coffee maker.
Turn the filter unit's round replacement date dial to two months in the future. This offers a reminder of when it's time to check and replace the filter.
Open the cage at the bottom of the filter assembly. Insert the soaked and rinsed filter cartridge, and then snap the cage closed.
Position the filter assembly directly over the water outlet in the base of the reservoir. Push the unit down slightly until the assembly locks into place. You should feel it click into position.
Oct 06, 2014 | Keurig B60 Coffee Maker
B200 stuck. says "brewing" but
Hi.You may try this steps.
took the reservoir off,
siphon water from a hose, blow it off
Maybe that is what has happened in
all of these instances
cup of coffee.Hope this helps.
Jun 21, 2011 | Keurig B60 Coffee Maker
When making coffee the full amount of water is not coming out only about 1/2 a cup
and getting the air bubble out gives us
a full cup of coffee.Hope this helps.
Jun 21, 2011 | Keurig B50 Coffee Maker
My coffee maker is only pouring half a cup
Jun 19, 2011 | Keurig B60 Coffee Maker
I have had my hamilton beach brew station for a year. The past 2 weeks, the water put in the bottom reservoir does not empty completely into the coffee reservoir. It leaves about 8 oz in the bottom water...
On your machine there is maybe inside water reservoir a hose or tube that goes down to bottom, or suppose to go down to bottom, to **** up all water. Look inside and see if hose is going all the way to bottom, maybe it got hung up or crooked. Please let me know, glad to help, thanks mike ( mr bean man )
Jun 08, 2011 | Hamilton Beach BrewStation 47214 Coffee...
Krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
May 25, 2009 | Krups Coffee Makers & Espresso Machines
Only takes a quarter cup of water to fill
Clean it out with 1/3 caraffe distilled white vinegar and 2/3 caraffe water - you will have to dump the existing water out first. Let the vinegar/water solution sit in the water reservoir for about 20 minutes, and then press the ON button to begin brewing as if it were regular coffee. You may have to repeat the procedure up to 3 times, but it should clear out the blockage.
Apr 14, 2009 | Cuisinart DCC-1200 Coffee Maker
My coffeepot the Gevalia model above will not brew this mornign
There's a little Thermocouple that can burn out on coffee makers, it's usually mounted by the warming plate. It's about an inch long and looks like a tiny bullet. It's a safety device and should be replaced, not jumped out. Radio shack may have them.
Geno
Jan 23, 2008 | Gevalia 25280 / 50304 / 60130 / 50431...
West Bend 56870 Coffee Maker Logo
96 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
ellenskitche
Ray Murphy
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
