Question about Hampton Bay 24002 Ceiling Fan
The fun does not move the air
I detected that the inclination of the blades are almost plane, So, I think that if I put some washers in 1 of the screws, they will inclnate a lite bit more the blades and I will feel more air. People said that it will break the motor. What do you think? Do you have another solution?
  • 34 Answers
Is it on reverse? Reverse it. Is it close to the ceiling? Replace it with other fan. Does it have no blade pitch? Replace the blade iron with a different one.
Posted on Jul 08, 2010
  • 706 Answers
Hello acaprotta96,
If you are concerned about the angle of the fan blades not positioned to move air, you can add washers to change that angle but you will need to do that to all the blades. The blades should be balanced to eliminate wobble. If I were you though, I would contact the manufacturer and state your problem and see if they offer replacement blade supports with a more aggressive angle. As for breaking the motor... highly unlikely. especially if you are installing an even distribution of washers to balance things..
Regards,
Rick
Posted on Nov 24, 2008
How to calculate coefficient of variation on TI-36XPro
As given in part three of the question, divide the standard deviation by the average then multiply by 100.
Sep 20, 2014 | Texas Instruments TEXTI36XPRO TEXAS...
How do i assemble a stanley block plainer
1, Lay pencil on the table top, place body of plane with the front (toe) resting on the pencil, so the light passes beneath the front and middle of the plnes body.
2, lay blade, bevel side up, in to body of plane, ideally sharp end is sticking out of the mouth ever so slightly., 1/2-1mm.
3, Release the knob or lever cam on the lever cap and place on top of blade.
4, tighten knob/turn leaver till it tightens on the blade. and your ready.
5, If the blade isn't protruding the mouth correctly then:
6, Loosen a knob/lever a little to allow the blade to just move, adjust the blade forwards/sidways, lock it in place by re tighten the knob/lever.
Plane a thin piece of wood, re adjust as necessary till wafer thin shavings collect in the mouth ontop of the bevel.
Aug 29, 2014 | Bailey Stanley 12-920 - Block Plane
1 thinks its wet , 1 sparks and snaps.
I took the blades and a washrag in the shower with me and cleaned them. Then I put them in front of the air vent for 8-10 hours. Then I put them back in the unit. Sparking and snapping could be from dirt moving through the unit.
Nov 21, 2013 | Sharper Image Hybrid GP Germicidal Air...
What kind of engine is used in airplanes?
The type of engine that airplanes use is the turbine gas engine, or jet engines. They have been in use since World War 2.
Aug 29, 2012 | Champion Sport & Outdoor - Others
Need to know how to get the blade off the miter saw to replace the blade
First, make sure it's unplugged.
On many saws the guard mechanism partially covers the bolt that holds the blade in place. Loosen and move the part out of the way as recommended by the manufacturer. On this saw you loosen a screw and then slide the mechanism up and towards the rear.
Press the spindle lock to lock the blade in place. Turn the bolt clockwise - opposite the normal direction - to loosen and remove it. Remove the outer blade washer and the blade. Leave the inner blade washer in place. Wipe a drop of oil on the surfaces of the blade washers that touch the blade.
Put the blade on the saw so that the teeth point down. Putting the blade on with the teeth facing in the other direction can result in serious injury. Put the outer blade washer in place. Turn the bolt counterclockwise until it is snug, plus another 1/8 to 1/4 turn. Replace the cover and you're finished.
Oct 27, 2011 | Saws
Planed board has a lower step than the rest of the board after passing thru planer , not equal amount planed off.
I think you are talking about what is commonly called "snipe". This is an inherent problem with all planers, but especially with heavier cuts. You can take lighter cuts, or you can start with a board longer than your intended finish length. You can also put the board you are planing on top of a longer board, then feeding them through together.
Sep 02, 2010 | Ryobi Thickness Planer Blades
My treadmill is stuck on a 10 incline and will not come down
incline motor is bad or needs calibrated, try this
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
Aug 04, 2010 | Nordic Track NordicTrack Treadmill, A2550
MTD 42" CUT MOWER MODEL 42A707 TYPE 1238 01 CODE960 2085A. 1) Mower blades do not stop spinning when deck is raised all of the way. 2) Left blade intermitantly makes a horrible noise when cutting grass...
I think either the bolt holding the left blade onto the spindle is loose, or the cup washers under that bolt are flattened or missing. As a result, the blade is slipping on the shaft and probably making a squeal or squawk. Take off the deck, flip it over, and remove the blades. Note if the bolts seem tight. And look at the washers stacked under the bolts. Replace any missing washers, or flattened cup washer. Make sure the cup washer faces the right way (hollow side toward the blade). Tighten things back up securely - it takes a hefty pull on the end of a 2 foot long wrench to get enough torque.
Jun 18, 2010 | Mtd Garden
Hampton Bay 24002 Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
