Question about Videoseven R17PS 17" LCD Monitor
Power light going to blinking amber
I have an intermittent problem where the screen either doesnt come on or goes off into a pseud power save mode? - ie the power light blinks amber, occassionally there is a clicking sound in time with the blinkig, and the light on the power supply slightly flickers gently in time. I have tried it on other PC's o same result - now I am not sure if the problem is the power supply or the monitor. It does work occassionally for periods of time? Is there a loose connection in the monitor?? Any help appreciated. Thanks.
  • 1 more comment
  • Steve Lewis Jan 02, 2007
    struggling to find a power supply vendor in the UK? either the wrong power or unclear as to the plug.
    Is it OK to cut the plug off, if I can get the right rating and solder on?
  • Steve Lewis Jan 03, 2007
    the power supply is external to the monitor - do you suspect the internal 'receiver' of the DC, or the power supply doing the transforming.
    Thanks for the help by the way!
  • Steve Lewis Jan 04, 2007
    Thanks again - I will investigate the options and economics of a solution!
  • 9,098 Answers
Sounds like a problem in the monitor's power supply. This will need component-level troubleshooting.
Posted on Jan 02, 2007
  • William Miller
    William Miller Jan 02, 2007
    When I referred to a problem in the power supply I meant inside the unit, not the power cord.
    This will need component-level electrical troubleshooting performed on the internal circuitry.
  • William Miller
    William Miller Jan 03, 2007
    Okay, I see.
    While the monitor does have an external 12V power supply, it will also have an internal power supply (inverter) which boosts the 12V to the higher voltage needed to power the lamps.
    I think the problem is in the internal supply (inverter).
    Again, this will need component-level electrical troubleshooting performed on the internal circuitry.
Printer won't print. amber light blinking.
try to power off printer remove the AC adapter, and hold down power button for 30 seconds, then plug in AC Adapter and power on, that may "Reset" the printer. You may be having an intermittent hardware failure. Let me know if this doesnt work. Thanks for any votes
Mar 27, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
New LG 2452T keeps going to digital power saving mode
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
Feb 28, 2009 | LG Flatron L2320A 23" LCD Monitor
Princeton LCD17 blinks off immediately
Check the VGA cord that connects from the PC to the LCD, try putting VGA cord properly to the LCD and PC, or change the VGA cord. saving mode indicates no signal from the PC. So either the PC is not booting up or VGA cord faulty.
Nov 09, 2008 | Princeton Digital VL1918 Monitor
Dell comp
To help you better , could you let me know , when the system goes into sleep mode, the power light in the front of the tower is it amber or blinking amber or is it of some other color.
If the power button is blinking amber , the power supply on the unit is going bad.
Thanks
Proton
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
Blinking power light
check your power supply. A flashing amber power button usually means its gone bad
Jul 15, 2008 | Computers & Internet
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
Problem with powerup for my screen
Although you didn't list your operating system, I'm assuming it is Windows and offering a suggestion to clear up the issue based on that OS. Go to settings, and then to control panel. Once in control panel look for "power settings" and click on "custom". This will allow you to turn off all power saving modes by clicking "never" on when the screen is turned off or goes to sleep. If the issue is caused by the power saving mode, this will end the problem.
Apr 24, 2017 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Monitor doesnt come on , but the power light goes from amber to green. then comes on after 20-30mins maybe.
Maybe update your display drivers. PC appears to be slow.
Make sure you don't have a bunch of apps that auto start.
Do you hibenate your PC?
Same issue if you connect monitor to another PC?
If issue follows you to a different PC it says monitor. If it doesn't it says the first PC (that monitor is currently connected to) had a cpu/memory or a driver issue.
Good luck
Oct 25, 2017 | Sony SDM-HX93 19" LCD Monitor
Videoseven R17PS 17" LCD Monitor Logo
239 people viewed this question
Top Videoseven Computers & Internet Experts
Alun Cox
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Videoseven Computer and Internet Expert? Answer questions, earn points and help others
