Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Touch pad how to silence key pad
    Brigadier General:
  • 7,752 Answers
Your phone manual will guide you as to how to do that.....or just go to your sound settings and deactivated the keypad sound
Posted on Dec 26, 2008
3 Suggested Answers
  • 3 Answers
SOURCE: I want to silence the key pad on my i530
Go to the menu go down to setting then to volume then keypad
Posted on Apr 07, 2009
  • 12 Answers
SOURCE: how to silence touch tone key pad
Menu - Settings - Audio & Ringtones - Volume - Key Tone and push the down on the dpad until it says Off.
Or (same path): Menu-9-1-3-4 then Down
Posted on Sep 12, 2010
Sharp squeaking from rt rear wheel. Might be a bearing but it stops if i apply light brake pressure
your rear brakes need servicing!!Those sqeaking noises are from metal pins within the brake pads. They touch the rotor surface when the pads are worn. Usually when brakes are applied they tend to silence the squeal. Inspect the rear brakes for pad thickness. Hopefully this helpd!!
Aug 14, 2010 | 2004 Toyota RAV4
Touch pad problems
Most of the toshiba laptops can disable touch pad with FN + F9.
In F9 key u can find touch pad picture.
May 27, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
How do I silence the key pad
Go to tone settings in the Menu Click on keyboard tones Put it on silence mode if stated OR bring the volume Level to zero
Nov 20, 2009 | Motorola Mobility RAZR V3
How to silence touch tone key pad
Oct 06, 2009 | AT&T LG CU515 Cell Phone - Black
Control beeps continuously. Display shows F1. Started when oven had not been used for a long time. Pushing oven and timer off buttons resulted in 10 seconds of silence before beeping resumed. Same for...
Usually, This means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 28, 2009 | GE Ovens
How to Silence the Key Pad
I called GE directly and they said there was no option to silence the key pad on this phone. (I think I'll return it).
Sep 11, 2009 | Uniden Cordless Phone
My toshiba laptop cursor doesnot move when i touch the tray pad
Hi!
I had the same problem after my fat cat sat on my keyboard. This is how I fixed it. At the top of the keyboard there is a F9 key. If you look closely at this key, it also has two pictures of the mouse pad. This key is a toggle that turns the mouse pad on and off. Down near the lower left corner of the keyboard is a key marked FN. Hold down the FN key and press the F9 key. That will turn the mouse pad back on.
BTDT, HTH
Jun 13, 2009 | Acer Aspire 5610-4648 Notebook
Dec 27, 2008 | Motorola Mobility i530 Cellular Phone
KEY PAD SOUND ON W377
Hello Velveteve,
Luckily for your housemates, there is a way for you to silence the keypad.
You'll need to go to your "Settings" Menu
Select Ring Styles, then go to ringer "detail"
If you scroll all the way down, you should be able to see "Key Volume".
Set that to "0".
Similarly, you can choose the "Silent" or "Vibrate" ringer option and that will temporarily silence your Keypad Tones.
Hope this helps,
cHiPz.
Mar 23, 2008 | Motorola Mobility W375 Cellular Phone
Silence the pad butons
I would think this is a design feature in the keys, unless it comes from the speaker. In that case check the jeyboard settings in the control panel.
Nov 07, 2007 | Gateway 2520915 Keyboard
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
