Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Around edge of tv the colors blue/red/green/blurry...
My parents projection tv is acting weird. The tv was given to them, and they say that the tv has always done this. I have pictures to show you what the problems are. Thank you for your help. Whats pretty funny is my mom lost her glasses about a couple of weeks ago and was using my sisters. The other day I was like why is your guys's tv do that? mom was like what are you talking about. I went to the tv and showed her that around the edges of the screen it would be blurry and the blue/red/green would be off, also on some tv commercials it would like squeeze the commercial so it looks like a bow tie. It also cuts dvd movies almost in half. She started laughing and thought that it was just her glasses cause they aren't really funny...Heres the url address for the pictures. Much help will be greatly appreciated Thanks
I've also tried Auto-Convergence and it's the same...
My 52" rca tv just started showing blue red double pictures yesterday...covergence don't show up on the set up menu anymore so i can not do much will it cost to fix this problem?
Posted on Nov 24, 2008
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
My RCA P52960 52in. rear projection tv has what looks like a slight Fisheye lense look to it,the center being perfectly fine but all around the edges is a slightly blurry and can see all three...
We calling convergence problem.
Re solder fly back terminal ( transformer)
Replace pico fuse 400mA(little red box fuse) beside fly back.
Go to set up, convergence, select auto convergence and your TV will work perfect.
I will be here for any future question.
Thank you for visit fix ya.
Aug 04, 2011 | RCA P52960 52" Rear Projection Television
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites,Tv reapair to buy CRT tube coolant to recharge ur CRT.
Feb 26, 2010 | Sony KP-46WT500 46" Rear Projection...
Have a rear projection tv 55pp9352. Has green halos around objects on the screen. Checked convergence and all red and blue line up except that on the outside edges the convergence crosses are somewhat...
yes, you need remplace the liquid in the picture tube green and blue, and need remplace 2 parties stk-392-120 and resistences 6.8 ohms at 1/2 watts
Jan 05, 2010 | Televison & Video
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Cant get the redd green an blue projectors to line up correctly
you need to have the set reconverged,,,call a repairman to come out and reset the colors
Mar 01, 2009 | RCA HD52W56 52" Rear Projection HDTV
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Mitsubishi VS-50703 blurry after move
A halo effect usually means the coolant in the CRTs need replacing in the effected color usually blue goes first followed by green. red seems to be less prone for some reason.
Jan 14, 2008 | Mitsubishi VS-50703 50" Rear Projection...
What do the colors look like? Does it look like you have more than one image, and the trailing edge of the second image is in a primary color like red or blue??
Dec 01, 2007 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
226 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
