Question about EuroTech 24 in. EDW194E Built-in Dishwasher
What is this part?
My husband recently installed our Eurotech EDW194E dishwasher, never used yet.
There is a white plastic piece, sort of shaped like an L if you stand it up. It is about 8 inches long and about 3 inches tall. The main part is about 1/2 wide, the little shelf thing on the botton (unless I have it upside down) is about an inch. It has a small piece that pulls out of the top, which has slots in it.
What is it for?
Should it be installed somewhere before we use it?
2 Suggested Answers
  • 6 Answers
SOURCE: Error messages on a EuroTech EDW154E dishwasher??
Eurotech Dishwashers are notorious for the E1 and E4 faults. The problem is with the solenoid they use for filling the dishwasher. The problem is something called the "Venturi Effect". The Venturi effect is the reduction in fluid pressure that results when a fluid flows through a constricted section of pipe. The fluid velocity must increase through the constriction to satisfy the equation of continuity. while its pressure must decrease due to conservation of energy. The gain in kinetic energy is balanced by a drop in pressure or a pressure gradient force. I know, a lot of big words. To put it simply, the orifice within the solenoid is smaller than the inlets and outlets. Even more simply put: Not enough water is getting into the dishwasher. It's a design flaw and I'm not certain there are many ways around it. Just make certain that you have a good water feed to the dishwasher (no kinks, valve on completley etc.). One thing you may try is reducing the feed pressure (i.e. slightly turn down the water valve supply to the dishwasher). Doing so may diminish the venturi effect by equalizing inlet pressure. It's worth a try.
Posted on Feb 07, 2009
EPSON STYLUS CX3200 How to place 2 detached springs and a black plastic piece ·L-shaped in the cleaning area of the printhead
you can resolve EPSON STYLUS CX3200 How to place 2 detached springs and a black plastic piece ·L-shaped in the cleaning area of the print head error by connecting Epson printer customer support number 1-800-213-8289. We assure you that we will givw you the best services.
Mar 13, 2018 | Epson Office Equipment & Supplies
My dishwasher displays a note h 03 what does that mean
I think that means it's not draining water correctly. My older portable dishwasher wasn't draining right and I found a small piece of white plastic had lodged under the float at the bottom which caused the dishwasher to think it wasn't draining. Look at the bottom of the dishwasher to find the float, usually round in shape and moves a little up and down when you gently pull on it, look for anything obstructing it's movement.
Jun 26, 2017 | Dishwashers
Water is puddeling on the bottom of my 18 yr. old GE dishwasher
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Sep 22, 2009 | EuroTech 24 in. EDW194E Built-in...
Part 1544681 has come off. Cannot reattach.
I have had the same problem twice. After paying for a replacement part and waiting for it to arrive once, i decided to try fixing it myself and came up with a fix that works realy well dispite the manufactures bad design. I used a small "Butterfly" bolt.23345fe.jpg Grind down the wings so they will rest only on the inside rim and allow the part to spin. Cut the bolt to the proper langth. Drill a through the middle of the larg part and use the bolt to hold it all together. Water can still pass around the bolt. Hope this helps.
Aug 29, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Installation of a new top spray arm
should only be a little plastic push in clip facing down towards the dw in the middle of that spray arm. should be able to pop it out. you may need to take the supply tube off the back so you can get a good look at it
Nov 21, 2008 | Dishwashers
Epson C 44 ink jet printer loose white L shape plastic part.
ONE OF THE ARTICLES IN, www.fixya.com/support/t262916-printer_carriage ,GAVE US SOME GOOD INFORMATION. IT REFERS TO A PAGE IN A PARTS MANUAL THAT WAS IN PDF FORM, WHICH WE HAD TROUBLE DOWN LOADING. WITH THE DOWN LOADING OF AN UP DATED ADOBE, WE MANAGED TO VIEW IT. THE ASSEMBLY THAT THE WHITE PLASTIC L SHAPED PIECE WAS MOUNTED TO WAS HANGING DOWN, AND HAD COME LOOSE. THE PLASTIC L PART GOES ON ONE OF THE SHAFTS ON THE LITTLE WHITE PLASTIC CARRIER, THAT MOUNTS INTO THE SLOTS. NOTE THEIR IS A SMALL SPRING THAT IS ON ONE SIDE AND IT ATTACHS TO ONE OF THE SHAFTS ON THAT SIDE OF THE WHITE PLASTIC CARRIER. PUT IT BACK TO GETHER IF THE PARTS AREN'T BROKEN AND THE PRINTER SHOULD WORK. I FEEL IT WAS THE SPRING COMING OFF OF THAT SHAFT THAT ALLOWED IT TO COME LOOSE, AND SHUT THINGS DOWN. GOOD LUCK
Jul 27, 2008 | Epson Office Equipment & Supplies
Latch stuck on bosch dishwasher
We removed the front door. Where the latch is located, there was a white piece with a pin sticking out and a cross bar that was held in place by the white piece. We used a screwdriver to open a space in the white piece so that the cross bat could slip out the bottom of the white piece. Then, we could push from behind on the metal part that had the pin. The metal part rotated and released the latch. We then replaced the cross bar into the white piece. Be careful -- the solution worked to unlatch the latch, but our diswasher still doesn't close well during the wash cycle.
Jun 16, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Third level spray arm
If your dishwasher is the same as our GLD2440REB1, the sort of star-shaped piece on the ceiling unscrews.  Then there's a sort of flangey washery kind of guy that you can poke through the star-shaped piece and snap into the arm.  Then screw the whole thing back on to the pipe.  I know this works, because I do it every time the arm falls off.  Which is every time I run the dishwasher.  ... Oh, crud.
Before I order a new part (spotted for US$7.65 plus shipping), I'm going to try putting some thread or a pin or something in there to hold it together.  Maybe some epoxy.
Am I a cheapskate or what?  :-)
Sep 08, 2007 | Frigidaire GLD2445RF Built-in Dishwasher
Error codes
Usally this is a bad control board or in some cases, a bad display board. they are fairly easy to replace and should be covered under a 5 year parts warranty (no labor). if its older than 5 years i would advise getting rid of it before putting any real money into it as Eurotechs are affectionatly know as Eurotrash in the industry and it WILL give you more problems. If you need a short dishwasher to fit under some shorter than standard counters, go with an ASKO. They are made by the same parent company, but are 50 times better. Good luck!
May 26, 2007 | EuroTech 24 in. EDW194E Built-in...
EuroTech 24 in. EDW194E Built-in Dishwasher Logo
Top EuroTech Dishwashers Experts
Tony Houde
Tony Houde
Tom Chichester
Dave Glabb
Are you an EuroTech Dishwasher Expert? Answer questions, earn points and help others
