Question about Panasonic SC-EN37 Desktop CD Micro System (037988255559) Docking Station
System is getting power, won't turn on
I bought this system for my husband last Christmas and initially we had trouble setting it up to play. Once we got it up and running it worked great for months. We recently had to disassemble due to a move and now we can't get it working again. We know the system is getting power as the ipod docking station indicator light is lit, however the power button will not turn on the stereo...nor will the remote. What could we be doing wrong? How can we get this up and running?
  • 1 more comment
  • kmaslin Nov 24, 2008
    Both my husband and I have tried to connect, re-connect and wiggle wires to no avail thinking it was a bad connection. I just tried again and nothing. Again, power is reaching the docking station...but we can't get the stereo to turn on. HELP!
    no switch in the back
    Have the manual and connections are routed correctly...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand the only easy user possible try is to reset the unit, that is unplug for an extended period of time hoping that it will revert back to factory default.
Addi tonally, you can try, press and hold the standby/power button on the remote and/or on the unit while plugging in.
Should neither be corrective, then there is an internal fault and would require electronic diagnosis and repairs. Is the unit still under warranty?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa
Posted on Nov 24, 2008
    Sergeant:
  • 207 Answers
On the back of the Left speaker there is an AC plug which the AC power cord attaches to. then there is also a cord marked DC that MUST go from the speaker to the main unit. Double check to verify that these cords are connected and fully seated.
If they are,and if I'm right in asssuming you got it for him last Christmas. Check your paperwork on the unit to verify how long the warranty is. Most electronics have 1 year or more. If the warranty is still valid, get it serviced before the warranty runs out.
If your warranty HAS lapsed my bet is that the DC cord from the speaker to the main unit probably got damaged during the move. Perhaps if you wrapped it around the unit or it got snagged in a box flap it could suffer from "Mechanical failure" (meaning that the wires when put under stress snapped inside the insulation.
you should be able to get a replacement from most electronics stores.
If its still under warranty get it repaired that route. (As opening the case will likely void the warranty)
For now I'm going to assume you know something about electronics. If any of the following does not make clear sense to you please comment back and I will walk you through it in more laymans terms.
Does the DC power cord attach to the SPEAKER by a connector? If so simply detach it and purchase a replacement.
If it is a formed connection (Passes through the casing) then look for all the mounting screws attaching the speakers housing together(Manufacturers sometimes like to HIDE them under stickers to provide a telltale sign of tampering) Open the speaker and look for the power supply board. trace the wiires from the DC power cord back to supply board and desolder the connections with wick or solder ******/bulb (Before removing look at the polarity of the lines. They should be marked either by COLOR or one of the lines will have a stripe in it). make note of which wire goes where.
Take the cord to an electronics parts store(Radio shack or any similiar store) to get the relacement.
as well as rosin core/flux core solder (Rosin/flux is a cleaning agent that melts just before the solder and cleans the metal to make as pure a connection as possible)
Install the new cord in the unit and try it out. If the left speaker sounds a bit "Tinny" you can try to fix that by sealing the grommet(Where the wire enters the casing) with a bit of silicone.
Hope this helps
Dave
    Top Expert:
  • Panasonic Master
  • 77,529 Answers
When you turn it on the switch operates a small power relay, this is what actually turns the unit on, these fail and create the issue you have. If you don't hear a click then the relay is defective.
  • 790 Answers
Hello!!
Do u have manual ??? Check out the connections using the schematic diagram!! If everything is proper.. then guess some pat has worn out.
  • Kanth raj
    Kanth raj Nov 24, 2008
    Guess the stereo connecting cable has been worn out..
    Scholar:
  • 126 Answers
Check the back of the system where the power supply comes out of the back. There may be a switch there that was moved over to a different power setting. Hope this helps.
    Sergeant:
  • 291 Answers
This is due to the improper or loose connections.reassemble it again and it will work.
Why would gould water pump red trouble light indicator come on when power switch turned back on after having been off for a few hours? Had to turn off power to pump earlier in day due to volatile elec
check and prime the pump as the light may indicate no water and so the pump will not run
foot valves leak back the water so it may need priming again
Jul 21, 2017 | Cars & Trucks
How long will batteries last if not used?
Get the batteries tested .As a motor mechanic your husband should know about battery care you could have removed them and charged them with a car battery charger or any of the trickle chargers used to keep batteries charged while not in use
May 09, 2017 | Pride Mobility Products Sonic Scooter By...
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
I bought a #7442 last Christmas and have not had a chance to use it until now. BRAND NEW, w/Carry Box and all. Anyway, my husband and I have spent ALL DAY trying to get it to work! We watched the DVD 5...
Not sure what brand of machine you have but generally after threading the bobbin the thread should be pulled out through a spring like device and by pulling on this thread and holding the bobbin case loosely in your hand, the bobbin case should turn clockwise inside the case. Clockwise is essential.
Then turn the machine by slowly by hand and let the needle go down and up once. Then pull up the end of the needle thread which should then lift the bobbin thread with it. Pull both through the back of the presser foot and start to sew. I hope.
Dec 08, 2010 | Sewing Machines
I haven't been playing my wii for a few months, but today I wanted to play, so I tried turning it on, and it didn't turn on! It was still all hooked up, but the red light isn't even on. I'm sure it's set...
Just make sure it is plugged in.If it was plugged in the whole time,you may simply need to unplug it for 5 minutes to reset the power transformer.If that doesn't work,you probably need a new power adapter.If you have anything that you do not use for months on end,you should unplug it and if it is battery operated,remove the batteries.Batteries erode very quickly when not used,and could make whatever they are in completely useless trash.Here is a link to Nintendo for further help and possible parts dealers.You can also try their troubleshooting help,but there won't be much difference from what I mentioned.Good luck,Greg
http://www.nintendo.com/consumer/
Nov 08, 2010 | Nintendo Wii Console
My daughters v. smile will not turn on
The ac adaptor has to be set to the correct voltage , there should be a small adjuster on the mains plug.
1.5v for each battery ( regardless of battery size ); so 6v for a 4 battery , 9v for 6 battery , etc.
Oct 15, 2009 | Vtech V.Smile TV Learning System (Pink)
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Removing random play setup
    try menu then system.
    i think that it is in there. I would go further, but am afraid it will do it to me. I too had that same problem. Good Luck
    Jan 18, 2008 | Creative Labs ZEN V Plus MP3 Player
    Remove random play
    go back all the way in the menu till you get to the begining and select music library, then go back to play mode and select normal
    Power Trouble
    Hi!
    First, you need to check the one that you got for replacement is the correct adapter for your system. If it matches with the old one, make sure that the ac adapter light (LED) is on when you plug it the wall outlet only. When you plug it in the portable and if your ac adapter LED blinks out (turns off) then the motherboard needs to be replaced or else the ac adapter is not working and needs another replacement. Call Dell and have it replaced if you just bought it.
    Hope this helps!
    Karlox™
    Dec 19, 2007 | Dell Inspiron 2200 Notebook
    Panasonic SC-EN37 Desktop CD Micro System (037988255559) Docking Station Logo
    273 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
