Question about Xerox Phaser 4500 Printer
Konica 7022 put 81/2 x 11on this feeder it reads size A3, reducing the actual copy. platen copy is fine. Is there a calibration procedure to correct this?
If you have a server you can do this on the server, the clients will recieve the instructions.
In XP go to printer properties of your 4500 printer. On the General Tab.
Select Printer Preferences, on the tab Paper/Quality change the document size to Letter and paper type to auto select.
(If server) On server do the same in the Tab Advanced under Printing defaults.
Now you can print on Letter (8,5x11), format.
Kind regards,
Mark Peters
Field Engineer.
Posted on Jan 12, 2009
I have canon Ir2270 machine. In this Computer print is ok but when copy to copy then large vertical white line is coming in the side.please help.
Him are you using the upper feeder or platen glass? . If copies are ok in platen glass . There is dirty in the feeder reading glass
Feb 05, 2018 | Canon Office Equipment & Supplies
Error code F 26-3 on Konica 7022
Sir/mam, you might have a bad drum density sensor or it was not cleaned or was destroyed by static electricity, if a vacuum cleaner was use to remove the old developer, NEVER use a vacuum cleaner for that procedure. Remove the drum and will see a small sensor near where the cleaning blade sits need to clean it replace it. Worse case the main control board is bad that what sensor talks to .Was the L Detect procedure run after the developer was replaced, and before you replaced the developer did you clear the developer counter, to let machine know it has new developer, because clearing the counter is the only way the copier has new developer, did you clear the counter for the new drum? The machine use the counters to determine voltages for certain assemblies. If L detect was not run and copies or prints where made get new developer and start over.
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Having reduced 3 inches missing copy print of Legal page (8.5 x 13)
me too having same problem in MS Office..but finally i observed sometimes paper sizes or try to reduce the paper size..
Apr 05, 2014 | Konica Minolta Bizhub 500...
Set print a3 paper
A3 is 11 x 17 paper in the inch world. place the paper in the paper tray adjust the guides then go to printer properties select correct size.
Jan 08, 2014 | Konica Minolta Office Equipment & Supplies
I need instructions for copyng from A3 size in A4 size
Place A3 Document on platen glass or document feeder. Click copy ratio button. You will get 2 options. (i) Preset:- Press minus key and select 70% (ii) Zoom:- enter 70 manually Press oik Enter no of copies, press start
May 02, 2011 | Canon iR 2020i Laser Printer
How to copy a3 to a3
simply place the original A3 size paper on the glass, now select the tray which have A3 size paper in it, now press the "start" key. you will get A3 to A3 copy....
Feb 18, 2010 | Konica Minolta bizhub C250 All-In-One...
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Copy count
You should be able to get the meter reading on a 7022 by pressing the star key (*) on the numeric keypad.
Hope this Helps
May 12, 2008 | Office Equipment & Supplies
Scanning on an mp500
First you should have installed the scanner in the computer using the cd comes with the scanner.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Load paper in the auto sheet feeder or the cassette in the portrait orientation.
  3. Lift the document cover and set a document on the platen glass.
    - Regardless of the document size, set it in the landscape orientation.
    - Place the copying face down on the platen glass.
    - Align the document with the alignment mark (shown as the arrow) on the lower right corner of the platen glass.
    Note: The machine cannot scan the area approximately 3 mm from the front and right edges of the platen glass.
    < 1 > Alignment Mark
  4. Close the document cover gently.
  5. Confirm that the printer is in Copy mode. If the printer is not in Copy mode, press the <COPY> button to switch into Copy mode.
  6. Check the copy settings, following the procedures below carefully.
    < 1 > Check the paper size and media type.
    < 2 > Use the up / down cursor button to specify the number of copies.
    < 3 > Use the right / left cursor button to adjust the intensity.
    Memo: Pressing the right cursor button increases the intensity. Pressing the left cursor button decreases the intensity.
  7. Press the <Color> button for color copying, or the <Black> button for black & white copying. (The printer starts copying.)
    Note: To cancel copying, press the <Stop/Reset> button.
Apr 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Oct 02, 2007 | Sharp AR-161 Laser Printer
116 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
