Question about GE Profile JGS968SHSS Gas Kitchen Range
Probe light The display is alternately flashing the probe and the bake light. The probe is not connected. I unplugged the stove overnight but the problem returned after plugging it in.
  • 2 more comments
  • marinelli Nov 22, 2007
    Am cooking my Turkey and don't know how to operate the probe so that I can get an internal temperature. Can you give me instructions?
    l. marinelli
  • kak109 May 14, 2008
    same problem, alternate bake and probe flashing.-
  • Anonymous Oct 17, 2008
    Same bake and probe lights alternating with beeping, occurred mid-cleaning cycle.  After reading here, I also disassembled probe holder.  Didn't see anything amiss, but took alcohol soaked q-tips to clean out inside of probe.  Very dirty.  Reassembled, turned on power, turned on oven and it is fine.  Thanks so much.
  • cpr4237 Apr 26, 2009
    Probe and bake light keeps flashing and the oven doesn't work.
I had the same problem today (my wife overflowed a pot of chicken stock last night, so there was liquid all over the cook-top, and some probably got down behind the control pannel). Based on the solution to a problem that seemed similar, though definitely not as exact as your description, I checked the probe connection (unscrewed the retaining nut, then unscrewed the two sheet metal screws holding the housing in place, then gave the probe connection a gentle tug to ensure that it was still properly connected). Finding nothing wrong, I replaced the housing and retaining nut, and the lights were no longer flashing.
Posted on Oct 22, 2007
  • peterho Apr 20, 2011
    where is the housing and retaining nut?
Unscrew screws and take back panel off of stove. Find orange and green wire that are together. About middle ways you will see a red connector. Pull this apart to stop the probe from functioning. It's my brother stove and he does not use the probe, so no more annoying beeps and flashes.
Posted on Jul 21, 2012
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
very likely your oven control it does those things without any input from the oven so if it doesnt do what it is supposed to it is likely bad
Aug 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Probe and Bake blink alternately.
I had the same problem. I resolved it yesterday. Detailed instructions can be found if you access my inquiry under the user name bhmlton. If you can't find them, then let me know and I'll get them to you another way.
May 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
See Below. By the way, this is a brand new stove.
if its abrand new stove i reccomend calling authorized servicer. no need for you to void any warr.
Mar 16, 2008 | Frigidaire FES367 Electric Kitchen Range
Baking oven
if you got no display form clock assy ck the power lines leading to that control, unplug and relpug unit might have just glitched out, no clock no bake on this model all oven function run throughthis clock/control
Feb 28, 2008 | Tappan TGF363 Gas Kitchen Range
KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Dec 10, 2007 | KitchenAid KGRC608LSS Gas Kitchen Range
F31 error code after self-cleaning cycle
Possibly the temperature probe, check the connection and the wiring to it. These ovens have very badly stamped metal inside that will cut through wiring very easily. Temp probe may be bad as well.
Dec 09, 2007 | Frigidaire FGFB75D Gas Kitchen Range
Stove controls beeping and flashing "Probe"
Most likely oven sensor / probe is the problem. It can be tested with an ohm meter. Not sure about your model, but most should read around 1100 ohms at room temperature. If there's a tech sheet somewhere on your unit, it should tell you.
Sep 23, 2017 | Jenn-Air SCE30600 Slide-In Electric...
GE Profile JGS968SHSS Gas Kitchen Range Logo
1,945 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
