Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp AR651 C37 error
I've got used AR651 recently. When I turned on machine first time after move on to my place sevice call sign has been poped up. It is C37. Would you please let me know what does that code mean? What should I replace?
Thanks,
David
  • 95 Answers
The C37 means a "transfer belt operation error". The transfer belt lift motor is faulty. More than likely the now bad motor has affected the board that drives it, so the logic board would need to be replaced at the same time.
Posted on Mar 21, 2009
Error c37 toshiba
Hi Ahmed - I'm not much of a copier tech any more, but I'm pretty good at looking things up.. :)
According to the link I found for you, it indicates a problem with the transfer belt cam motor. One contributor on another site wrote, "I don't have service manual. However you may try this; Press and hold 0 and 3 while turning on the power. Enter code 114. This will make the Transfer belt motor run. Press Clear/Stop to end the test." The page with error codes was found here: http://officeimagingsystems.com/id175.html - your machine is about 2/3 down the page. Another contributor recommended that you, " Examine the transfer Belt to check and clean it,contacts,wires etc.
Use a multimeter to check if belt motor is working or not.
If it works,it means you can have problems with wires,conntacts and LGC board." Other people pointed out it could be failure of the cam motor itself. I hope one of these bits of information leads you to a solution.
Finally, if you don't have a service manual for it, I found one you can download for free at http://www.feedroller.com/Store/Service%20Manual/SERVICE_MANUAL.PDF Best wishes -
Mark
Jun 15, 2014 | Toshiba E-studio 550 Copier W/net Print
Tip
Bread Machine Reports Error
We have had a few bread machines now and if they stop working suddenly this is one of the most recent issues that we have experienced. And has proven to work for us twice. The place the machine is stored is not typically very warm this time of year in our home and recently the bread machine has failed to start and delivered an error, and before I could even look up the error code my spouse got our hairdryer and warmed the machine up with it and then the machine started with out any error or problem. So try that before signing up to buy any pesky parts, because that is much more work.
on Jan 16, 2018 | Kitchen Appliances - Others
Bypass tray problem
What error does the machine display?
May 08, 2013 | Sharp Office Equipment & Supplies
The error message- Release the scanner lock- came on with the scanner UNLOCKED in the first place. I've troubleshooted and (flipped switch) unlocked scanner- several times- and turned MP830 off and...
I am not 100% sure on this but I do know that most printers and scanners when straight out of the box sometimes have tape or some foam that they use to keep the bits that move around from moving. I would check your manual from end to end and if you dont find anything in it then I would contact tech support for Canon as it may be that this is a bug of some sort that they may already have a fix for.
Jun 19, 2011 | Canon PIXMA MP830 All-In-One InkJet...
We have a sharp R-967 combination microwave/conventional oven. It now switches itself off after 59 seconds of operation regardless of which time and/or which function has been selected. Can this be easiliy...
I see its some time ago now that you posted this and perhaps you've fixed your micro already or replaced with a new one. I have the same Sharp r-967 microwave which had the same 59 second problem. I researched a bit online found the sevice manuals and tracked the problem down to be the damper motor. I managed to buy one online and replace it quite easily. There are some diagrams online when searching for this problem but for different sharp models where the damper is near the door fixings. Its not the case on r967, its behind the circuit board and easy to remove with a stubby screwdriver. You can find spares from this place. 5 minute job. The 59 second thing is likely to be the either the door switches or the damper motor. Switches are between £5-10. All mine were fine so didnt have to replace any. A quick voltmeter test can check them.
http://www.sharp-parts.co.uk/shopexd.asp?id=76
I paid £26 in delivery. Hope it helps if not too late!
cheers
Jan 04, 2011 | Sharp R-1850A Convection/Microwave Oven
Hi i recently brought a sharp arm 276 in denmark and transported here to london to give to a local charity. upon recieving it i plugged it in and afterpowering up it says on the display contact customer...
The L1-00 error code deals with the scanner not moving. Look to see if the scanner is not locked in place. Most of the time when a copier is moved they may lock the scanner down.
Apr 01, 2010 | Office Equipment & Supplies
Sharp 1540cs L-1 error, then L-5
Try cleaning the guide bar, then lube it with oil also clean your sensor under your carriage(blow it out with a can of air. If the problem persist check your belt and make sure its tight. You can adjust it from the left rear of the machine behind the Main board.
Mar 26, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Error Code F1-87 Finisher Trouble on Sharp AR-M350U+
It is a stapler rotation error. The stapling tray pressure arms become dull at the tips, so when the stapler attempts to move into position to make the staple it cannot move the guides out of the way.
First choice) Replace the (4) stapling tray pressure arms (LSTPP0357FCZZ). After you replace them you'll see that the tips get worn down, and wedge into place so that the black support plates cannot move out of the way of the stapler. The black plates look warped, but they aren't (I should say they always look like that).
They are fairly easy to get to. You do have to remove the finisher from the copier. Remove the front and rear covers. Open the right door. Pull the pins that retain the door. From there you'll see the arms. They can be changed with a little maneuvering.
2nd Choice) Clip overtight wire ties to the stapler rotation home position sensor.
3rd Choice) Shake down the stapler to its bottommost position (wherever it settles is fine). Adjust the flag that triggers the stapler home position sensor. If I remember correctly its the narrow **** in the flag.
Jan 28, 2009 | Sharp AR-M350U Copier
Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Nov 26, 2008 | Office Equipment & Supplies
PRINTER ERROR-CHECK CARTRIDGE
Unplug the power cord. Try to move the cartridge to the right by hand.
Oct 03, 2008 | Sharp INKJET FAX UX-A1000
Sharp AR-5316 Advanced Digital Imager Copier Logo
144 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
