The machine was there for some time without toner kit. i change the toner kit and the message dispalyed ... call for service c 6000 \\ please let me know . . thanks
SOURCE: KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Hi
Error C6000 means Broken fixing heater wire. In fixing warm-up, the time to reach
50°C/122 °F exceeds 13.5 s, the time to reach 100°C/212 °F exceeds 10 s, the time to reach the primary stabilization exceeds 10 s or the time to reach the secondary stabilization exceeds 24 s. To resolve this try this reset procedure--
Turn off the copier by opening the top toner cover. Turn copier on, when you see message "close top cover" press "system menu" button. Scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time. Now scroll down to "maint mode", press "enter" then enter 163 press" enter " turn off copier then turn back on.
If this doesn't resolve your issue then you'll need to check whether heater M or S is installed correctly. If it is installed correctly then make sure that the heater M or S wire is not broken. Hope this helps...
Daniel
