Question about Symbol LS2208-7AZK0100S Handheld
Setup Barcode Scanner to read book, cd's and dvd bardcodes.
How do I set up the scan codes in a Symbol LS4004-I049 Barcode Scanner to read barcodes from books, cd's and dvd's? I am new at using this device and any type of help would be greatly appreciated.
  • Bob Morris
    Bob Morris Nov 27, 2008
    I am also in need of setting up the LS-4004 to be able to read PDF417 barcodes. Binary Bob
Why doesn't my scanner send the data to my Excel sheet?
drivers are available on line for your machine
type in drivers for --( your machine ) and select free download.
Mar 16, 2015 | Symbol LS4004 (ls4004i0007705z) Handheld
LS4004 Scanner displaying 2 random digits on scan?
Hello coreyog. I think I can help you with at least part of this. The "suffixing with an enter" you're describing is called a Carriage Return. If you go to your manual, you'll be able to find the Carriage Return enable and disable barcodes. Disabling the Carriage Return should fix that part at least.
As far as the digits not found in the barcode, there are about a thousand and one reasons it could be doing this. Generally, I suggest to my clients that they use the manual to reset the defaults of the scanner while plugged in to the problematic machine, after resetting, unplug the scanner and plug it back in. This should get windows to re-discover the device, as it were. This takes care of it about 75% of the time. I hope I've at least helped you get a start on fixing your scanner foibles. Good luck!
Jan 06, 2010 | Symbol LS 4004i
I have an LS4004 scanner misreading a label in codeabar format. Can someone help?
Yes...contact me at 1-866-306-7226 or the Symbol Help Desk at 1-800-653-5350... you will have to enable "NOTIS EDITING" in the manual. That will strip the leading and trailing alpha codes
Oct 23, 2009 | Symbol LS 4004 (LS4004-1000770A)
Need User Manual for Symbol Barcode Scanner LS4004-1000. The two we have were manufactured in 1997 and 1999. HELP!!
This is the LS400xi Product Reference Guide. This contains all of the standard programming barcodes.
The Advanced Programmer's Guide contains barcodes for modifying the way the scanned data is sent.
Jun 12, 2009 | Symbol LS 4004 (LS4004-1000770A)
Symbol PDT 8100 and I2of5 barcode reading problems
Normally I2of5 comes disabled as default in wavelink software.
You will need to enable it and if you are scanning barcodes of different legths, set both the maximum and minimum to 0 value. This will allow any length.
If you still have problems, get back in touch with me and send me a sample barcode as I have a verifier which will allow me to determine whether there may be a problem or not.
Feb 09, 2009 | Symbol MC9090 Barcode Scanner
Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Jan 08, 2009 | Symbol MC9090 Barcode Scanner
Handheld Symbol LS4000-I100 barcode reader
you need to use the code book (the programmers book) to configure the reader, you need to tell it how to communicate with the PC (bit rate, stop bits etc....)
this code book should have come with the reader...
this book has barcodes on many pages and also configures the types of barcodes that the scanner can read....
if you do not have the code book you can download it from the maufacturers website
Jul 08, 2008 | Symbol PN: LS4000-I100 Laser Scanner...
Decodeing UPC-A Supplemental 2 or 5 code
you should have a code book that came with the scanner, the code book allows you to program the scanner's options, the code book takes you step by step through the programming proccess. each option requires you to scan varios barcodes to "set" the various options one of the options will be to set the barcodes you wish to use, this is set to avoid a misread (confusion between barcode standards)
Aug 07, 2007 | Symbol LS 4000i Handheld
Symbol LS2208-7AZK0100S Handheld Logo
699 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
