Question about Stoves 1000DFDLm Gas Kitchen Range
Low flame and not heating oven
The oven lights immediately but remains at a low flame and not heating the oven.the oven has a gas hob and gas oven with seperate grill
We had the same problem on our 10 yr old creda. gas man said new ffd required (flame failure device). he reckoned on around 80 pounds sterling for new part,even if it was still available, plus maybe 2 hours labour. we bought a new cooker!
Posted on Dec 20, 2008
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
Oven wont turn on
I have a delongi oven and hob hob is working fine but the oven isnot im turning the nob on the front of the oven and ignition on lighting is fine after I release the knob on the front the supply turns striaght off no flame no gas nothing
Apr 04, 2011 | DeLonghi Ovens
Hi, got old Eurolec Gas oven/hob. Hob lights up fine. Was cooking in oven all morning, no probs. Tried to light oven for evening meal & gas will not stay lit, goes out once ignitor & temp' dial...
Hi, your thermocouple is faulty, it is the little probe like thingy that sticks up into the pilot flame. It is there for safety purposes, detects flame and holds a valve open magnetically to allow the gas to pass through. Try giving it a clean with a scourer, sometimes works, or your pilot flame is not big enough, could be low on gas or unit needs a service Kristian KJ Tech
Sep 15, 2010 | Microwave Ovens
It won't heat up... even though there is a flame
Check The Power Source
If the gas oven won't turn on, the first thing to do is check the power source. Most modern gas ovens are electrically powered. Check to make sure the oven is plugged in and the breaker isn't tripped.
Check the Heat Source
When a gas oven won't heat, the pilot light can also be set too low; if the pilot is lit but the oven isn't catching, adjust the flame.
Newer gas ovens use electric ignitors that produce sparks. If the oven doesn't heat, the ignitor could be broken.
Feb 05, 2010 | Ovens
Trouble lighting gas oven. Brand is a Chef
your thermocouple needs replacement
Aug 31, 2009 | Ovens
Two Gas hob burners will not remain alight
Does The thermocouple NOT hold at all or does it go out on low ? make sure the Flame heats the thermocouple , have you tried of disconnecting the Thermocouple from the Magnet and just clean the terminal on the T/C Have you measured the T/C Millivolt reading ? Have you got a clean connection on the Electromagnet ,Chech for bad solder joint in the Magnet
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
Main Oven will light and remain on, however there is no temp adjustment even after a time delay Model Parkinson Cowan SIG 454
Hi
The problem you have is this:
The FSD (Flame Safeguard Device) is faulty. This is what it does....
When you turn your oven on the FSD allows a small amount of gas through to the burner, the lit gas heats the FSD and says yay we have gas!, it then lets more gas through!
If it's broke it just keeps it on low flame.
You need to get a qualified Gas Engineer to look at it for you
I hope this helps
Steve :)
Jul 14, 2009 | Kitchen Ranges
Stoves 1000DFDLm Gas Kitchen Range Logo
774 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
