Question about Motorola Mobility RAZR V3
My phone say
(invalid battery when is charging)n turn off every 5 minutes ,but i put another battery n it say the same thing
    Brigadier General:
  • 7,752 Answers
The firmware needs to be flash back in the phone to correct this issue
Posted on Dec 28, 2008
When i start up the phone its shows invalid battery but i replaced new battery still it not works
1. connect your charger and wait about 1 hour (off position)
2.turn on your phone
3. pull out battery
4. put battery back and push battery until connect with the socket battery
5. if it doesnt work doit step (2.3.4) until show charging note
ps: it work on my motorola v6 ferrari edition
Apr 27, 2012 | Motorola Mobility RAZR V3i Cellular Phone
Not charging shows invalid battery
took your motorola l7 battery out clean the battery connector or put air pressure by your mouth and before all that change your charger
Apr 14, 2009 | Motorola Mobility SLVR L7 Cellular Phone
My phone keeps saying the battery is invalid...
You might have a 'cooked' battery. If they are left charging for prolonged periods, the battery is heated and charged excessively, and will no longer work properly if even at all. You may need to purchase a new one.
If not it is the conection to the battery that is in the phone itself.
Feb 13, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
VX9400 problem
I had the same issue, but knowing some things about computers, I took the battery out for about 3 minutes or so to let the phone lose any charge it had. Then I put the battery back in, held the send button in for a minute then pushed the power button and it turned back on fine.
Oct 04, 2008 | LG VX9400 Cellular Phone
Motorola invalid battery
Do this and see if this works
Pull out the battery when the phone is turned ON(remove the battery when the phone is working.)
wait for like 15 to 20 seconds
Put the battery again and turn the phone ON
Jun 07, 2017 | Cell Phones
Invalid Battery
Totally discharging the battery is the way to go. But what you can also do to use your phone in the meantime is this. Plug your charger into the phone withOUT your battery in. It will tell you "Unable to Charge." When it says this, put the battery in. It might tell you "Invalid Battery" a couple more times, but it did eventually say "Charging Battery" for me. After that, simply turn the phone on and it will return to normal. This is when you drain the battery completely. Once I did that, I did not get the invalid battery error again.
May 14, 2008 | Motorola Mobility RAZR V3
Invalid Battery
Try open up battery, put it back in & plug in charger again.. wait for a bit then turn phone back on. Hope this helps!
Feb 20, 2008 | Motorola Mobility RAZR V3
Battery charging
there are two things mainly, first ur battry is weaken now or ur charger can have problem also ur phone can have problem with in itself better u take it to technician so it can be checked for exact fault and can be repaired.
Jan 12, 2008 | Samsung C417 Cellular Phone
Battery
Try cleaning battery contacts with a pencil rubber. It worked out for me
Jul 17, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
110 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
