Question about Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster
Toaster will not stay down in toast position
I have ths Back to Basic toaster /egg poacher
The toaster will not stay in the down position
Toaster does work if held down.
I have taken the plastic cover off.
The white plastic part that guides into the copper guide on the toaster side seems to have a portion of the the white plastic missing!
How can i obtain a replacement part of the white plastic part?
  • 1 more comment
  • krystin181 Dec 27, 2008
    ditto
  • budhead Jan 03, 2009
    toast
    will not stay down.
  • Anonymous Feb 26, 2009
    I have 3 toasters with the same problem; I've only had them 1 year.
    Problem Solver:
  • 14 Answers
The toaster lever is held down by a magnetic coil.
It is the small cube shaped thing with the red wire would around it. More than likely the coil is open. Second guess would be the coil is not being energized.
Outside chance the problem could be mechanical and related to the steel plate that will set on top of the coil when the lever is pushed down.
Posted on Feb 18, 2009
  • 62 Answers
Uh, don't think there's a good chance, you could try to send toaster in for repair, but buying a new toaster is probably cheaper.
Posted on Dec 09, 2008
Help my toaster doesn't toast my eggs
Your toaster may not be intended to toast eggs.
Oct 09, 2016 | Toaster Ovens
Can I purchase a new poaching pan for the back to basics muffin toaster and egg poacher?
Yes! West Bend apparently now owns Back to Basics; you can order replacement pans from http://www.westbend.com/finditem.cfm?itemid=3733
Feb 10, 2011 | Back to Basics TEM-500 Egg & Muffin...
Back to Basics TEM-500 toaster no longer heats up
We have the same problem after only about 20 uses. The customer service number is 1-800-688-1989...we may be able to get it replaced. If they aren't willing to do anything, I'm thinking of filing a complaint with our state Attorney General because there are SO MANY complaints of the SAME, idential problem from thousands of consumers!!!!
Jan 02, 2010 | Back to Basics TEM-500 Egg & Muffin...
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
Paula deen toaster with egg cooker
the toast part works but the egg part does't
Aug 20, 2008 | Back to Basics TEM-500 Egg & Muffin...
Back to Basics egg toaster
My egg cooker stopped working, so I took the unit apart. To answer your question, I did not see a fuse inside. One way to tell if it is a power problem to the mother board is to observe whether the LEDs light up or not after pressing the switches. If the LEDs don't light, there could be something wrong with either a power component or a power connection.
In my case, the toaster worked fine. Usually these problems are caused by loose connections. Sometimes it is not obvious where the loose connection is. All I did was loosen and re-connect the wires to the egg cooker and also to the board they came from. I also shined up the toast slide button copper connections with a nail file. This was just a precaution, since the toast slide button had to be working (i.e. it still toasted, just didn't cook an egg).
So far, it seems to be working, but time will tell. If the problem was due to something other than a loose connection, it will happen again.
Apr 14, 2008 | Kitchen Appliances - Others
NEED EGG POACHER TRAY
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=4155&secid=53&linkon=category&linkid=98
$5.00 plus shipping or somewhere around $10. How much is a new toaster? I just scrubbed the remaining coating off my replacement pan that also peeled and it works fine. $10 is too much money for something that will peel just like the original. Too bad they won't make them available in stores that sell the toasters and at least save the consumer shipping.
Apr 12, 2008 | Back to Basics TEM-500 Egg & Muffin...
4-slice egg & muffin toaster
On my fourth one now...love the idea, but the egg poacher keeps burning out.
The 800 number is 1-800-688-1989
Calling them now...this last one only lasted 3 weeks.
Jan 21, 2008 | Back to Basics TEM-500 Egg & Muffin...
NEED MANUAL
I found this on the Focus Electronics website, which is Back to Basics and West Brand.
http://www.focuselectrics.com/supportdata/TEM4500_manual_np.pdf
Jan 19, 2008 | Back to Basics TEM-500 Egg & Muffin...
Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster Logo
680 people viewed this question
Top Back to Basics Kitchen Appliances - Others Experts
Ian Summerfield
Ian Summerfield
L Vincent Testa
L Vincent Testa
Are you a Back to Basics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
