Question about Muratec Office Equipment & Supplies
Muratec MFX 1330 "call service 004" put in new drum and this came up on display
  • dld9 Nov 24, 2008
    reinstalled drum and it works thanks
    Sergeant:
  • 276 Answers
The new drum which you put in must not be installed properly
Posted on Nov 24, 2008
Reset code for muratec mfx 2010
Is it the drum counter? You can only reset when you put a new drum it it.
http://www.fixya.com/support/t18621752-muratec_mfx_2010_reset_drum_amp
Jan 04, 2016 | Muratec Office Equipment & Supplies
Call servce 18 muratec mfx 2010
muratec mfx 2010 call service 18 problem
Oct 14, 2011 | Muratec Copier
Please call for service
If the machine is saying "Please Call Service"..you will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Mssge will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common( given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts.
Oct 23, 2010 | Muratec - MFX-1300 Copier
We replaced new drum and copier says not usable
The drum should only be replaced when the display says "REPLACE DRUM" ...NOT when the display says "Replace Drum Soon"
...try the following...... Press PROGRAM,*,*,I(thats capital letter i) then press ENTER.
SHOULD RESET IT
Sep 03, 2010 | Muratec - MFX-1300 Copier
Muratec MFX 1430 Fax / Printer / fax does nto turn on.
UNFORTUNATELY YOU MAY HAVE LOST A PCB. IF THERE IS NO DISPLAY AT ALL YOU WILL PROBABLY NEED A SERVICEMAN. WOULD STRONGLY SUGGEST YOU GET EQUIPEMENT LIKE THIS ON A "SURGE-PROTECTOR". ITS A LOT EASIER TO REPLACE A $25 SURGE PROTECTOR THAT POSSIBLY HUNDREDS FOR A NEW PCB.
Jul 08, 2010 | Muratec Copier
Muratec mfx 1300>> CAN I reset A "replace
YES....try the following...... Press PROGRAM,*,*,I(thats capital letter i) then press ENTER.
SHOULD RESET IT.
Jun 16, 2010 | Muratec - MFX-1300 Copier
I replaced the drum in the fax machine and it still say i have only 14 copys left, how do i reset that? I have muratec fax MFX 1700
You are not supposed to replace the drum until it says"replace drum"
Not when it is saying "replace drum soon."...you have prematurely blown fuse in the cartridge so now it will not reset.
Try the following...
Press...PROGRAM,*,*,I(That is Capital I), then ENTER.(SHOULD RESET IT.)
Nov 16, 2009 | Muratec MFX-1700 Fax
Reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Sep 15, 2009 | Muratec MFX-1430 Copier
How do I reset the drum counter on a Muratec F320?
Ok, this is how I resolved it for my fax machine.
I powered down the fax, removed the new drum and reseated it.
When I powered it back on the counter reset itself as it is supposed to.
Nov 12, 2008 | Muratec F320 Plain Paper LED Fax
73 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
