Question about Sony Cyber-shot DSC-W50 Digital Camera
Image size over
Sometimes when i take a photo and then go to playback mode to view it the photo is shown in a reduced size and cannot be altered. If i try to zoom or resize it says "image size over". I have tried various settings and it seems to be happening at random. please help!
  • 2 more comments
  • Anonymous Jun 30, 2008
    At other times when viewing the pictures in playback mode, the photos get sheared and discolored (random colors appear on the sheared portion). Please help!
  • ahowe16 Oct 06, 2008
    I have the exact same problem too with the image size over.  I have no idea what to do to fix it.  In the manual under corrective action for this problem it just states, "You are playing back an image of a size that cannot be played back on your camera."  Duh.
  • jeannine615 Nov 04, 2008
    my camera also does the same thing and the images also gets discolored and broken!! help pleasee..
  • Anonymous Jan 26, 2009
    I also have the same problem! Help.
Change a brand new original memory stick
Posted on Jun 22, 2007
How to view dates while printing for Lumix DMC - TZ3
The camera will not show the date while taking pictures. The camera can stamp the date onto the photo, but the image size will be reduced. See page 66 of the manual: http://service.us.panasonic.com/OPERMANPDF/DMCTZ2.PDF.
However the date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jun 26, 2013 | Panasonic Lumix DMC-TZ3 Digital Camera
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
Displays file error message when trying to playback still images and video footage
Did you take the card and insert into computer/device to view photos?
Viewing photos can alter the format of the photos thereby preventing your camera from reading them.
I viewed some photos and rotated a few photos and my camera no longer recognizes the format.
good luck
May 20, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Reducing image size
You can change the record mode in the camera to shoot at a lower image size of 640X480 by changing from HQ to SQ mode. Page 72 of the instruction manual explains how to change the record mode setting. You can also use photo editing software to reduce the image size down to 640X480 which is equivalent to the size of a 3X5 photo.
Mar 18, 2009 | Olympus D-490 Zoom Digital Camera
Saving zoom in photos
You can't. The inphoto digital zoom is just so you can do it. The best thing to do is download the photo to your computer and then use the camera software to zoom/crop etc. Then you can save the altered image.
Dec 25, 2007 | Olympus Stylus 790SW Digital Camera
Reduce Photo
You can use Photoshop to reduce Photo size to a minimum size that can be mailed and u can retain the resolution by it. Its afantastic application. Open your image in photoshop and right clik it on the top of the title bar choose image size and change the resoution to 150DPI or lessere but not less than 72 DPI.
R u can go to save as command in the file menu and save it for Web option is better to reduce the size of the image to very smaller one which can be mailed.
Thanks
Nov 09, 2007 | Adobe Photoshop 7.0 for PC
The size of the images are too big
Use your favourite image editing software in Vista. Or use the software that came on CD with your camera (if it is not the one that runs on XP only). Anyway as alternative solution you can either shoot photos in lower resolutions (1Mpix for example) and then the files won't be so big. But you will have only the small photo and no large one. Or shoot as usual, then switch camera to "play" mode and when viewing images on camera, there is a menu option to resize the images - you can resize them to 1Mpix for example. In the meantime search web for some free image editing software for Vista.
Jul 17, 2007 | Panasonic Lumix DMC-LS70 Digital Camera
Sending photos as an e-mail attachment
When sending photos as e-mail attachments, the image (file) size should not be too large. Use the included image viewing program called Image Expert to save photos in reduced size. For instructions on installing Image Expert, see "Installing the image viewing program" on page 42 of the Instruction Manual. 1. Launch Image Expert. 2. Choose "Open Image" from the "File" menu. 3. Specify the image you want to reduce, then click "Open". If the camera is connected using the USB cable, it is displayed as a removable disc. images on the camera can be opened directly by specifying the remove-able disc. 4. Click on "Change Size" in the "Image" menu. 5. Input values at "Width" and "Height", then click "OK". If "Keep Aspect Ratio" is checked, the size is changed without changing the image’s vertical:horizontal ratio. 6. The image is displayed at its new size. 7. Click on "Save As" in the "File" menu to save the image with the new size.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Cyber-shot DSC-W50 Digital Camera Logo
253 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
