Question about Asko D1796FI Built-in Dishwasher
Asko D1796 will not start properly
My Asko D1796 all of a sudden after 3 years of flawless operation will not start. I turn the power on, select the cycle and start it. It makes the draining noise for a few seconds and instead of filling up with water, the heating element comes on. I've tried turning it on and off. Cutting the power at the circuit breaker and it doesn't change. Even if I select the rinse and hold cycle with no heat involved it does the exact same thing and the heating element comes on. Please help. I just had a party and my dishwasher is full and my 3 year warranty just expired. What happened?
  • Anonymous Mar 27, 2014
    water is not going into dishwasher and dishwasher very hot when door opened
  • Anonymous Mar 29, 2014
    will not shut off, even with the door open. just keeps running in the drain cycle, with the plate and glass icon blinking. even turning the breaker on and off does not help
  • 175 Answers
It sounds as if you may have A bad control board. It could be causing the heater element to come on when its not supposed to (usually a stuck relay) and not filling the machine with water. you could also have a bad control board AND a bad fill valve, as a stuck relay for the heater shouldn't affect the fill valve circuit. The bad news is that these asko control boards are $350 to $450 for just the part, the good news is that the control board is under a 5 year warranty (for only the part, not the labor to change it) as are the pump motors and any timers. Also, if you are just out of warranty, find your date of installation, as asko warranties start when you install it, not when you buy it (if you moved into the house and it was there when you moved in, and you are the first owner, submit a date of occupancy and that's when your warranty started)
Posted on Jan 13, 2007
I have an ASKO D1716. Once started, it does not stop. I tried the rinse cycle and it advanced towards to setting 2. But, it continued to operate long past its normal time limit. (I have two of the...
here is a site with the fault codes and how to check for them.
To start the trouble-shooting programme, press the
Temperature selection button five time within 15 seconds. code chart info click on the link below.. Jay
Asko D1796 Use And Care Manual Fault Indications
Feb 10, 2015 | Asko D1716 Built-in Dishwasher
Sony HCD-GT222 Hi-Fi CD and cassette deck with tuner, suddenly started to shut itself down at volumes higher than 50%, after three years of flawless operation.
It's thermal; protection is happening probably due to bad ventilation. Fuzz and dust can block air vents.These need to be vacuumed out now and then.
Jan 22, 2014 | Audio Players & Recorders
My ASKO D1796 seemed to be exhibiting the typical impeller issue - water fills at the beginning of the cycle nut the wash arms don't turn, unit gets very hot inside. However, I've removed the pump unit to...
You may have a bearing problem...
but It sounds like you have a motor problem... the power is going to the motor but the motor for the pump is not turning...
I would check for power to the motor and see if it is getting power... if not then trace back why it is not getting power...
heatman101
Dec 09, 2010 | Asko D1796FI Built-in Dishwasher
Asko D1796 control panel will not reset....it is showing 5 on it
shut power off at breaker, look under washer there is a pan, if any water is in that pan, there is your problem, remove the water with a towel, plug washer back in
Oct 31, 2010 | Asko D1796FI Built-in Dishwasher
Water pump gone on our d1796 and asking $450 to fix also rinse aid broken as well. Washer is 7 years old. Is it worth fixing. Thanks, Greg.
$450 Wow.... 7 years old, in my humble opinion.. NO WAY. It is better to put your money into a new one rather than have "Fixed" one that may break down again, once things start going... well.. you know the story I am sure.
Feb 09, 2010 | Asko D1776 Stainless Steel Built-in...
My asko D1796 dishwasher has turned itself to 'flood mode', how can I fix this?
Try tipping it over to get the water out of the base that is activating the flood switch, removing the kick panel and drying with towel and hair dryer. If there is no majour leak you should be back in action.
Hope this might help
Dec 01, 2009 | Asko D1796FI Built-in Dishwasher
ASKO D3251 flashing error message; drain gurgling, power off
You most likely have a leaking bottom spray arm. The water is in the pan under your unit. It requires dealer service. If you are still in your 3-year warranty, good; otherwise be prepared to put out hundreds of dollars. I'm going though this now for a second time on my $1600 D3251. Asko did grant a one-time extension on my warranty since it expired a month ago. In 6 months when it breaks again, I'll buy a Bosch. I also had this same problem on a previous Asko. I can't get more than 3 years out of these units, so this is my last Asko. When it breaks again, I'll go with Bosch. Good Luck.
Mar 17, 2009 | Asko D3251HDSS Stainless Steel Built-in...
ASKO D 1796 NEEDS COMPUTER BOARD
FIXYA does not know of any used appliance retailers . check with a local repair shop .
Aug 04, 2017 | Asko D1796FI Built-in Dishwasher
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Asko D1796FI Built-in Dishwasher Logo
846 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
