I recently bought a macbook air.and i was trying to change the password and i messed up somehow and now it shows a question mark ive tryied the little techniques like command key.shift etc but i cant figure it out/it on occasion said redoing internet connection it asked me to pick a carrier.but then it stopped that.i even tried holding command and r,n.at the start but it kept going back to the question mark
SOURCE: Popped off key on macbook
Well, you can pop the key back in , but you have to line up the hinge part to the 2 joints on the membrane. If you're not sure, make the appointment and take thr drive, it's worth not voiding your warranty incase something else costly might happen down the rod. I know its a pain, but if that is the only issue, than you're.
SOURCE: Macbook keeps restarting
all macbooks have a security that will not let you switch the harddrive from one the the other. Apple will need to reset the computer at an Apple store!!! His drive is DEAD!!!
SOURCE: macbook will not connect to wireless connection.
Since you mentioned that you moved your computer from one place o another, you need to make sure that there's no possible interference between the computer and the router (i.e. thick wall, glass door and other wireless device). You have to make sure that the Mac book is away from a wireless phone that might interfere with the wireless signal.
Another thing, you may try changing the channel of your router, if it is set to channel 6, try using 4 or 8.
Try to disable and re-enable the airport of the Mac book and see if that would work.
Last, try connecting into different router.
HAve a great day!
SOURCE: Airport connection says Connection Timed Out.
I don't think this is a problem with your macbook, it is probably a problem with the wireless router that is broadcasting the connection. Try restarting the router and connecting then.
SOURCE: Intel Macbook Flashing Folder, wont boot DVD
Just a note--any Universal retail OSX install disc will work. It's only a machine specific disc that won't unless it's for your model.
