Question about Neovo F-417 17" LCD Monitor
Monitor OSD won't turn off
Ever since yesterday, when I rehooked my desktop back up (after being repaired), the OSD has appeared in the middle of my monitor. It is circling around for the various functions, but I can't get it to turn off. I've tried hitting the AUTO button for about 10 seconds, which it then clears off the screen, but as soon as I release the button, the OSD comes back. This is really driving me nuts, as its right in the middle of the screen and you can't see anything around it. Any suggestions would be very welcome. Thanks.
  • Anita Chalk Jan 03, 2007
    Thanks for the advice Microwave Syc, the pin looks fine, but I'm taking it in to the shop as I discovered it had a 3yr warranty and can be fixed/replaced under warranty (I thought it was only 1yr). The computer shop guy has heard of this problem before, so I'm going to let the experts handle it now. THanks again.
  • Streetmedik Jun 14, 2008
    I have the same problem with the emachines E14Te monitor. I have
    emailed emachines support several times and no responce. Iave tried
    calling, and vet the computerized maze of press the number for X
    department. I have yet to talk to anyone in their support problem area.
  • 9,098 Answers
It may be a bent or broken pin on the connector of the monitor cable. It should look like the attached photo. It could also be a damaged or worn cable. It's also somewhat possible that it's a problem with the PC, but I doubt it.
Posted on Jan 02, 2007
Anyone experienceing this will be going nuts from experience. I just had this problem again for the 5th time it must be and mine did go away the other 4 times for months.
This time i had enough opened up the monitor and just disconnected and removed the circuit board and now it stopped! yet to have any problems again but i really would recomend this if you have no warrenty.
Posted on Jul 25, 2012
I had the same problem 2years ago, under waranty replaced.
Now (this evening) i have the same problem, i think there's a fabrication problem with all of these monitors !!
Posted on Sep 17, 2008
Monitor has been fixed under warranty - no need for any more suggestions. Thanks to all.
Posted on Feb 18, 2008
  • 4 Answers
If under warranty this is always the best solution. If not thought there is a fix posted for this problem allready. http://www.fixya.com/support/t117851-menu_screen_appears_all_time_flashes
Posted on Feb 17, 2008
Yes I got it fixed. I took it to my computer shop, and they took it to the company's distribution/repair centre here. Came back next day or two fixed. Don't know exactly what the company did. Sorry can't be more help.
Posted on May 29, 2007
4 Suggested Answers
SOURCE: Menu screen appears all the time, flashes through different categories
I tried cleaning the plate as suggested but had the same problem. So I decided to see what would happen if I disconnected the button board all together. I haven't had a problem since. I don't know if this is a good idea or not but it worked for me. You need to make sure the monitor is in the on position before you do so. Since obviously you can't turn it on or make adjustments to the monitor afterwards but I never made any adjustments to it anyway.
Posted on Feb 01, 2008
SOURCE: Auto adjustment.
Try this one:
the is not the same problem. But the cause is exactly the same
Regards
Posted on Feb 10, 2008
  • 1684 Answers
SOURCE: AG Neovo X-17a
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 17, 2009
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
A white block appears in the middle of the screen... it says" OSD lockout" occasionally it will disappear for a moment, but then returns or a large black box that has "Main Menu" at...
Fix One: Plug in the monitor and power it up. Hold down the Powerbutton until you get a message saying "OSD Unlocked". If the problem persistsafter OSD is unlocked then unplug the monitor from the wall, wait 20 secondsand try again. Fix Two: Turn on the monitor and hold down the Menu button for 10-20seconds. This should unlock the OSD. Fix Three: Turn off the monitor, press down the Menu button and thenturn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Aug 10, 2011 | HP Pavilion w22 22" LCD Monitor
An OSD message appears in a box that covers much of the monitor screen. The mouse pointer disappears behind the box whenever I try to sweep into it. The box will not go away (except intermittantly)...
OSD means On Screen Display. To unlock the OSD hold the power button of the monitor until you get a message similar to "OSD unlocked".
If you still have problems, click on this link for further instructions :-
http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
Dec 29, 2010 | HP Computers & Internet
The OSD screen is up and won`t dissengage(after trying the 10 second hold down) , also the video display say`s switch the cable leads , I don`t understand. The menu,+,-, auto buttons won`t work. What might...
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Mar 23, 2010 | HP RY117AA w2408 24" Widescreen LCD
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
W2361vg
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
Aug 29, 2009 | LG L1915S 19" LCD Monitor
Monitor power light blinking on and off but no picture
try testing the monitor on another computer. if you dont have an extra desktop or laptop to test with. take over to a neighbor or a friend. if the monitor still doesn't turn on or no signal. the monitor is defective and needs to replaced or repaired by a technician
good luck
Feb 28, 2017 | Dell E173FP 17" LCD Monitor
OSD lock - I think
This is for Viewsonic LCD, but it's probly pretty similar for you...
OSD and Power Button Lock Modes
OSD Lock This mode locks all current control settings and prevents access to
the control menus until this mode is unlocked.
? OSD Lock: Press and hold [1] and the up arrow  for 10 seconds. If any
buttons are pressed the message OSD Locked will display for 5 seconds.
? OSD Unlock: Press and hold [1] and the up arrow  again for 10 seconds.
raj, rajkumar.ranju@gmail.com
Jul 22, 2008 | ViewSonic E70f 17" CRT Monitor
Osd display
Is it LG hisync monitor? It's normal but mine is 10 seconds before it appears clear and I did not see osd.
Dec 15, 2007 | Computers & Internet
Neovo F-417 17" LCD Monitor Logo
1,784 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
