Question about Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Lens:Canon Zoom Lens EF 75-300mm Fix?
Hello- And Thanks for your help in advance. I dropped my camera bag and after the drop, I noticed the end of my lens had broke. It split where the filter threads into the lens end. The part that broke was right along the threads themselves. Looking at the lens, I see three small screws which seem to be connected below to the part that broke so I was assuming this piece could be replaced. I can send photos of the lens if needed. I guess I'm looking for that replacement part and a price if possible.
Here is everything I see on the lens:Canon Zoom Lens EF 75-300mm  1:4-5.6 III USM  Ultrasonic  1.5m/4.9ft
  • Jeff
    Jeff Dec 07, 2008
    NOBODY HAS EVEN ATTEMPTED TO HELP WITH THIS PROBLEM....   : (
  • Jeff
    Jeff Dec 08, 2008
    No clues out there, huh?  Just trying to avoid a trip out of the mountains to a camera repair shop. About 40 minute drive one way. Was hoping to help reduce all that driving cause I'm assuming this is an easy fix. Oh well. This site has tons of potential. Great idea. But without the premium service, it's kinda like a ghost town over here. Everybody wants the green first..
    Have a great holiday season anyways...
5 Suggested Answers
koraypek
  • 6 Answers
SOURCE: Canon Rebel XTI Ef-S Lens stuck
Hello Pittsburgh! I lived there for 3 years! Dreadful city. :-)
Now, your lens must have a problem with the guide rails/pins. If you dropped it or bumped it, you might have broken/damaged those guide rails. Another reason might be sand/grit in the zoom mechanism.
You may try stripping the lens slowly and see if you can identify the problem. Most lenses are easy to disassemble, you start from the rear mount area, take off screws, and parts one by one, and be organized (i.e., take photos for every step and don't mix the screws).
Good luck.
K.
Posted on Sep 21, 2008
t00nz
  • 4738 Answers
SOURCE: How to rapair Canon IXUS 950IS - aka Powershot SD850?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 19, 2009
  • 10 Answers
SOURCE: Camera was dropped-- "Lens error-restart camera" message
If it is still under warranty , please repair it.
If it is out of warranty. Try to get a quote, it the quote is more than 50% of original value , forget it.
For digital camera's they die like flies. New ones are better and cheaper anyway.
Posted on Mar 22, 2009
  • 164 Answers
SOURCE: see dust or drop of water on my pic canon sx10 is
You have to disassembly your camera for it, including the lens assembly.
Even if you have experience and skills in fixing electronic devices, I don't recommend it, since any particle of dust will get inside the lens and your camera, and will affect it.
The recommended place to perfom such cleaning activity is a Clean room (class 3 or higher), and have handy the proper cleaning tools.
Disassembling the lens is tricky and also needs a lot of patience and technique skills to do it properly.
Imagine that by accident a spring pops up a tiny metal ball (1.5 mm diameter) and you lose it in your home, then because of it, your lens will not work properly.
If it has warranty, I do recommend you to send it to cleainig to a professional repair and cleaning service.
If still you have questions or doubts, or need a cheaper quote for it (after get some quotes from local repair centers for comparison), you can contact the ebay seller Great_items_2004
Best regards,
Posted on Jul 25, 2009
Testimonial: "THANK YOU"
SGNath
  • 170 Answers
SOURCE: i dropped my camera and the lens was attached, in
That was a very sad thing to happen. There is no quick fix solution for this. You should take it to an authorized service center. But I fear this is not going to be an inexpensive process. Let them have a look and assess the damages. We have no way of judging what could have happened inside--whether there has been any misalignment of elements or focusing mechanism.
Posted on Dec 13, 2009
I bought Canon EF 75-300mm III Zoom Lens, but the len is very loose, is it problem
Long and short of it...if the photos are close to "decent", dont worry bout it :) It aint no L Lens but can still throw out a good pic every now n then. Tip it from one end to the other whilst holding it...if you hear something go \'ring-a-chicka-chink-chink-clunk\', then youve got problems, otherwise grin and bear the looseness - mine lasted 6 years of hard yacker before i dropped it in the drink!
Mar 27, 2014 | Canon 75-300mm f/4-5.6 III USM EF Lens
I dropped my 70-200 2.8 canon IS lens. The lens appears finebut autofocus no longer works* What are my best options for repair? My lens is less than a year old bought new. It is also very tough to move the...
Best option for repair is CanonUSA repair service (presuming your are in USA). Your warranty will have their contact info, or you can get if from their web site. Though still under warranty, since it was dropped, I'd guess they would charge for the repair (but might be kind enough to give you a break on costs). Another possibility is a local Canon authorized repair shop, but what, and the extent, of damage may preclude anyone other than Canon's repair location from attempting any repair. Dropping it is a bummer, huh?!
Oct 10, 2010 | Canon EF 70-200mm f/2.8L IS USM Autofocus...
My lens is locked and i cannot zoom
I had the same problem with the same lens. Over a few months it got lose, eventually getting so sloppy that it dropped if my 40D was held down. 10 days ago it jammed and the zoom was locked. I sent it to Canon and received it back in a week and it is now like new. Please don't try and fix it leave it to the experts at Canon. Not sure what the cost was as mine was still just under warranty
I think that this is a common problem with this lens and beleive that something in the lense works loose and eventually drops into the mechanism.
Jun 28, 2010 | Canon EF-S 17-85mm f/4-5.6 IS USM for EOS...
Dropped lense, hit the outer ring, now won't
No quick or cheap fix, but definately a lens worth fixing- send it to Canon
May 11, 2010 | Canon EF 70-200mm f/2.8L USM Lens
Canon 24-70MM 2.8 lens screw housing damaged
With a lens of this quality its worth checking whether it's repairable. try Protech, Uckfield for an estimate
Mar 15, 2010 | Canon EF 24-70mm f/2.8L USM Lens
Dropped my canon power shot a1000is...now lcd says lens error, restart camera (lens won't extend now)...Is this an easy fix or expensive?
Hello
Thank you for using FixYa for your problem
Zoom les is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 20, 2009 | Canon PowerShot SX100 IS Digital Camera
New Camera
Get the Canon EF 70-300mm IS USM about $500 and EFS 17-85mm IS USM about $300. The 75-300 all of them I would not use them 4 a body cap. Camera is fine or step up to XSI.
Jun 10, 2009 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
Cant adjust below f/5.6 on a eos 40d
You are correct in thinking that it should be possible to set the aperture wider than f/5.6 at the wide end of the zoom range.  My best guess is that the lens is defective.  I'd suggest returning it for a replacement.
Dec 21, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
EF 24-70 lens droop...
The zoom creep is an easy fix for Canon. I really do not recommend trying to tighten it yourself, since that would void your warranty.
It is usually free to tighten the zoom ring.
/Chris
Dec 13, 2008 | Canon EF 24-70mm f/2.8L USM Lens
Good luck.
K.
Aug 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens Logo
198 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
