Question about Hitachi 50VS810 50" Rear Projection HDTV
Hitachi 50VS810 I have an issue with this TV It seems there is a yellow color always, more often when I watch hockey for instance.....I see yellow in the center of the screen, yet the outer edges of the screen is the vibrante white , that you would expect to see. I really never noticed it until I saw my brothers identical unit, which was flawless running HDMI from HD SAT box, all connections perfect any ideas? I have tried a new Hitachi replacement bulb, cleaned all interior panels, to no avail Any help or input would be more than appreciated regards John
  • 2 more comments
  • BULWINKLE Nov 07, 2007
    I HAVE A 05 60 INCH WITH A VERY SIMULAR PROBLEM ONLY I THINK ITS MORE OF A GREENISH YELLOW, VERY DISAPPOINTED IN THIS INVESTMENT OVER 3000 DOLLARS AND A TERRIBLE PICTURE. IS THERE ANY ADJUSTMNTS THAT CAN BE MADE? HAVE TRIED EXPENSIVE CABLES, NEW LAMP, AND S VIDEO CABLE NO LUCK!!!
  • Anonymous Jan 19, 2008
    I have the same problem yellow smear in the middle of the screen.
    Really notice when watching hockey games. Called Hitachi they said
    it was caused by the sattilite feed. I disagree
  • Gdaddy Feb 09, 2008
    Feb 8, 2008
    Tonight my son noticed an area of yellow to yellow-greenish discoloration on the bottom half of my Hitachi 50v710. At first is was hard for me to see, but I fear it is getting worse. My set had the lamp go out last fall, which was replaced under warranty. I will attempt to post follow-ups as I learn more.
    zehurt@gmail.com
    P.S.-
    There have been two possible diagnoses posted in reply to the Yellow-green discoloration problem. One of them said the problem was the Light Engine and the other said it was the Optical Block. Can someone please explain what the difference is and how to discriminate between the two . I really don't want to sound like too much of a dummy when I talk to Hitachi customer service and/or Warranty representative.
  • Anonymous Sep 12, 2008
    MY HITACHI IS YELLOWISH GREEN ALL THE TIME. DO i NEED A NEW LAMP?
    Sergeant:
  • 308 Answers
It could be that the "White Uniformity" needs to be adjusted which would probably require an authorized service technican to perform. Otherwise, the problem may lay within the light engine itself, also requiring a tech.
Posted on Jan 01, 2007
Phillips Magnavox 9P6040 C104 tv color adjustment help
If you turn color off and stand back and examine the screen---if it is not black and white but yellow looking you have bad Glycol in the blue picture tube which is quite common.
Easy way to know for sure is with set on and rear cover removed peek with a small mirror at the three lens---don't touch anything with the set on===each tube red,blue, green should have a picture with the set on.
Likely you will find the blue one looks like a floodlight with little or NO image/picture.
May 18, 2012 | Hitachi Televison & Video
We have a hitachi ultravision model # 50vs810 made in 2005 our problem is when we turn it on the screen seems as if the whole thing should be kinda blue but the corners are kinda black then when we play...
Your TV has a defective optical block which should be replaced by a TV technician only. Due to the cost of the part and labor, it is almost less expensive to replace the TV. The part number for the optical block is UX23751 and is available at the following web site. I hope that helps : )
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/50VS810/Hitachi+Ltd/Hitachi/UX23751/New.aspx
Jul 25, 2011 | Hitachi Televison & Video
My Hitachi Ultravision LCD rear projection 62
Hi:
The only way to repair this is to replace the optics engine assembly, Light engines are rather cheap these days, try looking on www.tristatemodule.com for a new or refurbished one.
Apr 09, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Loud noise coming from the back of my Hitachi TV 50VS810 when it is turned on, still have picture and only way the noise will stop is to unplug
sounds like u have got cheap rca wires and ur getting feedback get some monster cables and change them that should fix the problem
Feb 24, 2010 | Hitachi 50VS810 50" Rear Projection HDTV
Near the top of the tv the objects are double exposed with in blue and yellow color.At the top of the tv in a light color you can see a faint color of yellow and blue that sort of swoops down like a...
Hi,it seems you are experimenting a light engine problem.This is how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Hitachi or look for your light engine online.God bless you and your house!
Nov 25, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Blinking lamp light
The lamp is bad and needs replaced, i have the same problems with my Mitsubishi 58" DLP
Oct 01, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
Product- 50VS810 Hitachi TV Replaced burnt out
check your lamp and lamp door saftey switches. If they are ok then could have also got the ballast.
Aug 09, 2009 | Televison & Video
Yellow coloring on Panasonic TV
IN THE MENU FIND COLOR CONVERGENCE TO FIX THAT
Nov 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Hitachi 50VS810 should we be worried...
No problem. The set will not be affected by the speakers near it.
Nov 11, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 50VS810 50" Rear Projection HDTV Logo
396 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
