Question about Equator EZ 3612 CEE Front Load Washer/Dryer
I need a diagram of an Equator EZ3612CEE door
I am trying to re-attach a door on my combo washer/dryer. i need a diagram of an Equator EZ3612CEE door, preferably exploded to see the point where the bracket on the door attaches to the cabinet.
Anyone know where to get this? I tried the equator website, appliance desk where i order the part, etc. But I appear to be missing the nuts that attach to the back of the door handle inside the cabinet. i just need to be sure.
thank you for your time.
Brandi
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 37 Answers
While you may have removed the door with the hinges from the cabinet the nuts may have fallen down on the unit.
You may want to open the back panel or the bottom panel and try searching for the same, in case you need assistance mounting the bracket back on the cabinet once you have the nuts do let me know.
Posted on Feb 26, 2010
Water not draining even after reset attempts
Did you check the most obvious item - the motor and belt that spin the drum and powers the pump assembly
Sep 12, 2017 | Equator EZ 3600 CEE Front Load Washer /...
Tip
Door not opening in Equator / Hirundo (EZ3612CEE/EZ2512CEE/EZ1612V)
Door not opening in Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door in the unit is not opening it means that the unit has not completed the cycle selected or else there is something in the unit that has malfunctioned. In such cases if there are clothes in the unit, one tries to open the door by pulling the door handle which mostly results in breaking of the door handle and also the clothes in the unit cannot be removed
To avoid the breakage of the door handle and also the damage to the clothes you can follow the following procedure to open the door.
  1. Make sure that the machined is turned OFF.
  2. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  3. Turn the wash program knob to cycle no. 4 & advance the knob by 6 clicks in the clockwise direction.
  4. Turn the machine ON by pressing the ON/OFF Switch.
  5. You will observe that the machine starts draining out the water and also the drum starts moving ( goes into the spin cycle)
  6. Wait until the water is drained out of the machine, this can be understood by paying attention to the sound made by the drain pump when it initially starts draining out the water and once the water has been drained out.
  7. Once you are sure that all the water in the unit has drained out switch OFF the power.
  8. Try opening the door now, the door should open.
Once you have managed to open the door, it is advisable to reset the unit first before further using the machine. For the Reset Procedure Click Here
on Mar 01, 2010 | Washing Machines
Equator Washer dryer combo......door wont open. Finished a funky cycle drained but wont open? :(
You will have to follow the drain out procedure and then the reset procedure.
Please see the link :http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Be careful, if you try to open the door by pulling the door handle too hard it may break.
Do let me know if this resolves the problem or else I may suggest something else.
Mar 26, 2010 | Equator EZ 3612 CEE Front Load...
Equator Wash dial just spins
just bought this ez 3600cee it says its ventless ,but yet came with
a venting duct work why?
Nov 29, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Combo Washer-dryer
Just for your information, you can call Appliance Desk and speak to their technical support to understand the wiring diagram.
You can download the manuals from their website as well which www.appliancedesk.com
Jun 29, 2008 | Equator EZ 3710 CEE / W Ventless...
EZ3612 - spins for couple of times then stops with burning smell and mode light blinking 13 times
Per the service manual, if the mode light blinks 13 times, there's a bad dryer sensor or thermostat. I'm not sure if that related to your problem but it's a start.
Doug
Feb 24, 2008 | Equator EZ 3612 CEE Front Load...
Broken door handle...
I have the same problem and I have a makeshift solution which I was able to do in 45 minutes and total cost was less than $1.
Step 1: Remove door from machine.
Step 2: Disassemble door with the two plastic donut shells. This means removing 6 or so flathead screws. Take care to note alignment of glass parts because they aren't perfect circles and only fit one way.
Step 3: Pull out pin that threads the spring and broken plastic handle remnant and metal latch piece.
Step 4: Discard broken plastic and replace the rest of the apparatus. The metal latch can move up and down, but that's ok.
Step 5: Purchase a paint-can opener:
http://www.istockphoto.com/file_thumbview_approve/525566/2/istockphoto_525566_opener_for_paint_can.jpg
Step 6: Re-attach door.
Step 7: You can use the paint-can opener to the right of the latch to lever-open and lever close the latch in order to open and close the door.
Cheap, easy. Not pretty at all. Definitely something your friends would make fun of you for doing, but it saves you $1,000 of a new machine, in this economy.
Jan 19, 2008 | Equator EZ 3612 CEE Front Load...
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
265 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
