Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
EI error code.
The EI error code comes up. The model i actually have is a LG LD-14AT2. I have checked the manual and it says this is a water leakage problem. There are no obvious signs of water leakage. Does anybody know what i can look at to try and resolve this problem?
  • 2 more comments
  • oach Jun 16, 2008
    We have an LG LD-14AW2 (approx 5 years old) that was running perfectly until we removed it to lay floorboards. Upon re-installation it would not fill and began to leak . We put in for repair but was told it ran perfectly. Filled normally everytime and did not leak once.
    We have once again hooked it back up and after about 2 - 3 cycles of running perfectly, same problem occurred. Would not fill and water leaking. Any idea what would be causing this problem when The service man could see nothing obvious wrong with the unit??? We have had to rip floor boards up twice now and are very apprehensive in connecting the dishwasher again.
  • costumier Jul 21, 2008
    I also have the LG LD-14AT2 model giving the EI error code, after three years of trouble-free operation. The code comes up about 4 minutes after the cycle starts. After the error code comes up and, and I pause the machine, and open the door, water continues to trickle into the machine from the vent about half-way up the left-hand interior side of the dishwasher; this then drains freely away. There is no external leaking.
  • Anonymous Mar 14, 2009
    Set dishwasher to go and comes up with same
  • colijn Mar 14, 2009
    Set machine to go & comes up with same code and alarm rings continuously. Does not proceed to wash dishes.
    Problem Solver:
  • 10 Answers
E1 on any LG d/w means the water pressure is insufficient due to the wash motor being faulty and /or the capacitor connected to it.
take care.
Posted on Jul 22, 2008
  • LG Master
  • 909 Answers
Open door and note if snough water is in chamber. if not possibly water pressure related or possibly faulty flow switch if it uses one,also check sieve for partial blockage. Take note if drain pump motor comes on as this typically denotes a leak in the sump which has activated the flood float limit.
Posted on Aug 22, 2007
I just had a service tech from Best Buy tell me I don't have sufficent water pressure to fill the dishwasher in its alloted time. so it times out and says there is a water leak. I'm waiting to hear from LG about this before I call a plumber.
Posted on Jan 03, 2007
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
E1 code comes up on the display, but how do you solve this? ...
E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
Feb 18, 2010 | LG 24 in. LD-12BW5 Free-standing...
Water heater no go.
The heating element is turned on first during the main wash cycle, which could be approximately 10 minutes in. Since this error is coming up, the first thing to check/replace is the heating element.
I am only familiar with the LDF family of LG dishwashers and on them, to get to the heating element, you pull the dishwasher, invert the entire DW and remove the access panel.
Good Luck, please post back here what you find, OK?
May 07, 2009 | Dishwashers
I have a LG Diswasher LD 2050 with a trouble Code E1. The manual says "Water leakage in hose connection" "water is leak by damage" Ihave check and everything is Okay. It let water in and when it start...
The most common problem on an LG dishwasher when error code E1 is reported but there is no actual leak found is the problem of a natural syphon being created by improper installation of the dishwasher. Pretty easy to fix:  Either add an Air Gap valve (available at any hardware store for almost free) or follow the drain hose from the dishwasher to the drain. Raise the hose and attach the hose to the up onto the bottom of the countertop. Adding that "rise" eliminates the possibility for the syphon effect to drain the dishwasher before the drain cycle begins.
If the hose ever fall back down, the problem will return immediately.  Adding the Air Gap valve is harder but is far more permanent (and complies with construction codes that really should not be ignored.)
Apr 17, 2009 | LG 24 in. LD-12BW5 Free-standing...
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Aug 25, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Lg dishwasher model LD - 14AT2
E1 is usually a very common fault of the wash motor not working.
The impeller breaks away from the motor shaft and doesn't spin, therefore, it doesn't pump water.
There is a sensor that activates with low pump pressure, which shuts down the machine and displays the error, E1.
The only other causes (that I'm aware of) are leaking water supply hoses, or pump blockage, but the motor fault is by far the most common.
Hope this helps.
Mar 18, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD 14at2 lg dishwasher
Does it display an error code" eg: E1
Jan 05, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-14AT2 - Error message about filter
HI, WE HAD THE SAME ERROR AND WERE ADVISED - AFTER WE CLEANED EVERYTHING - TO NOT USE A LIQUID CLEANER AND USE A TABLET.
Nov 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher model LD-14AT2
normally means not heating check element and use less soap
Nov 25, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
634 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
