Question about Oritron DAV3101 PROGRESSIVE SCAN DVD
Microphone inputs put the mic in and can not get sound.the red light on the screen comes on but no audio.
    Scholar:
  • 168 Answers
U need to turn on the mic in the menu
Posted on Jan 17, 2007
  • trouble31093
    trouble31093 Dec 29, 2013
    how do i do that
Vertex 2200 transmits but makes no sound
You mean NO Audio Transmit?
If there is No Audio at PTT Bad MIc Cord.
Change the Mic cord.
Dec 01, 2013 | Vertex Cd Vx-2200 Vx-2100 Series...
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
I hook up the microphone and no voice sound comes out what should I do
Where did you plug the Mic ?. Most receivers do not have Mic input. Only some DVD players with karaoke have a MIc input in front. The phones socket in front of the Receiver is meant for headphones.
Mar 14, 2011 | JVC Audio Players & Recorders
I can't use my hp microphone keeps saying no audio input device
First of all check in the BIOS that the audio device is enabled. Then, in Device Manager, check that the sound device is properly recognized and it's driver is active - if not you will have to reinstall it. Finally , from the Realtek Control Panel check that the mic socket is correctly identified and active - take the mic out, start Realtek Control Panel, plug the mic and the corresponding icon should light up if all is ok. If it lights up but you still don't have a mic or it doesn't light up at all then the mic is dead , replace it.
If it lights up but it blink it means that it's not recognized so another window will popup, select the mic in it and it should work.
Jul 05, 2010 | HP Computers & Internet
How to get output in speakers from mic via laptop
youneedd to go to the sound controller on your laptop and check in the properties for your sound card that the input has your mic selected and that it has been enabled go to start then control panel then audio and sound the box for mic or input is there make sure your mike is selected
Jul 29, 2009 | Samson R21S Microphone
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Apr 08, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Microphone(MIC)Of head set not working(got removed wrongly)
This usually just gets reinstalled whenever you restart your computer be it Vista or XP. In your case, the drivers for the Microphone probably got deleted. The Microphone driver comes in the package together with the sound card. You'll have to re-install the whole sound card driver to have it start working again. You can do this from the Device Manager. After doing this, the microphone together with the whole sound card drivers should start working again.
Sep 17, 2008 | ASUS M2N-E SLi Motherboard
Realtek audio device with sound effect menager
First thing is first, there should be 3 audio jack inputs. Line in, Line out and Mic. Make sure you are plugged into the Mic input.
Next if you are running windows XP check to make sure the Microphone volume is not muted and turned up. Do this by going to control panel --> Sound and Audio Devices --> volume tab --> Advanced button. The Microphone volume should be there if not select file --> properties and make sure microphone is checked. It should then appear on the volume controls.
This should take care of it if not what program are you using the mic with?
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
How to use blue usb mic
It depends on your operating system, but in XP, open Cubase. Go to the audio input settings, and be sure to select "USB Audio Codec" or "USB Audio Microphone" as the input device.
In Vista, right click on the speaker icon in the taskbar (usually lower right hand corner of the screen) and select "Recording Devices". Make sure to select the "USB Audio" device, then try Cubase again.
Dec 25, 2007 | Blue Microphones Ball Professional...
Televison & Video Logo
Top Oritron Televison & Video Experts
jairo sanchez
 Grubhead
Grubhead
Mikee
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
