Question about Imperial IFS40 Deep Fryer
One burner puts out soot.
One of the three burners burns yellow flame and puts off soot that is everywhere.
also takes 45+ minutes to heat the oil
  • Anonymous Mar 26, 2014
    black soot yellow flame
    yellow flame black soot
    Novelist:
  • 125 Answers
Hi there, I believe that the burner you are having a problem with, needs the inside of it cleaned, probably has alot of dust inside, or some material is in/on the orifice where the gas enters, you could also have an alignment problem with the orifice, causing a disturbance in the flow of the gas/air mixture. In addition it sounds like you may have a gas pressure problem, you should contact your gas supplier to have it checked, or call your local service company.
Hope that helps, and thank you.
Posted on Feb 21, 2009
    Genius:
  • 1,199 Answers
The buRner that puts out soot need to be adjusted down a bit!
Posted on Dec 06, 2008
I'm getting a lot of soot from my propane fired fryer. Otherwise works well.
The burner flames must be BLUE. Yellow flames will produce soot. Sounds like the burner orifice size needs to be checked.
Feb 27, 2016 | Pitco 40D Frialator - Commercial Fryer,...
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
SOOT PROBLEM CAUSED BY YELLOW FLAME
If they burn yellow then they are blocked IE lack of air causing flame to burn floopy yellow hence soot , clean burners and orfices to burners .
Mar 25, 2012 | Grilling
What causes carbonmonoxide in a furance
Carbonmonoxide is produce through the combustion products. If you have a crack in your heat exchanger it can spread CO though out your space. VERY VERY VERY VERY DANGEROUS THIS CO WILL KILL YOU!!!!!!!!!
Apr 30, 2011 | Goodman Heating & Cooling
Heater fires up and runs for a few seconds and shuts off think the heat exchanger is filthy would that cause it.
There are several things that can cause this:
Check for blockage in the flue pipe or improper flue design resulting in inadequate venting.
One way to quickly determine a venting issue is to visually observe the flame on the burn tray. It should NOT be yellow and should burn evenly across the burner. There should NOT be any areas of the burner that appear to burned or deteriorated. Look for evidence of leaks,
You may need to dismantle the top section of the heater to visually inspect for sooting.
You may need to inspect the flame sensor mechanism (if applicable) for dirt or sooting.
If it is determined that your exchanger is sooted up, you have a blockage in the flue pipe or improperly designed flue.
Nov 28, 2010 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
My pitco 35 c the flame is burning yellow and not going inside the very wall i thought it might be the regulator pressure on the fryer on the back side
Low gas pressure will produce low flame quality (yellow flame).
Check and remove any dirt or soot on burner holes, and orifice
Burner flame not going inside the fire tube could be due to soot or carbon build up inside the fire tube blocking the flame path, check the inside of the fire tube, if considerable amount of soot is seen, better have them removed.
Yellow flame will cause a lot of problem on fryers if not corrected as soon as possible.
If you have doubt on your gas regulator, better have a qualified service technician to check it.
Sep 02, 2010 | Pitco Frialator 35CS Deep Fryer
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
Burners with yellow tipped flames
I have a G.E. natural gas cook top. All 4 burners have a lot of yellow flame all of a sudden. Is there an adjustment for this I could make? Please explain the best you can.
Jan 05, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Zanussi gas stove
three problems with slow ignite on stoves.. first one is clean ignitors and burner caps. make sure that the caps and burners are correctly assemble. and make sure the stove is grounded correctly.. Do you flames have orange to yellow tips then there is a unburn carbon thst will form soot. soot productions is not achieving complete or efficient burning...again you may have dirty ot clogged burners..the flames should be all blue...let me know what you find out
Aug 31, 2007 | Kitchen Ranges
Imperial IFS40 Deep Fryer Logo
387 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Joseph Hoffmann
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
