Question about Panasonic TH-50PX60U 50 in. Plasma HDTV
TH50PX60U screen issue
I have a TH50PX60U and the screen is damaged. Not the external, the layer beneath, it appears to be a mesh-like material (hard to tell). I have a back-ground in electronics and if I could identify this, I would order it and attempt the replacement. Any ideas? I am also looking for the service manual, from what I understand, Panasonic wants $30, I am looking for the freebie though.
It would be so awesome to get this up and running, any help would be greatly appreciated.
    New Friend:
  • 45 Answers
DON'T BUY PANASONIC - UNRELIABLE!
Posted on Aug 23, 2009
If the screen is cracked (glass is broken ) you will have to replace the panel at about 1200 to 1500
Posted on Dec 18, 2008
Blackflag bug zapper does not kill bugs
We know that electronic mosquito zappers usually come exactly in the form of a badminton racket, and quite similarly have a net woven over its top circular frame; whereas the handle part consists of an electronic circuit and a battery pack integrated with the net assembly.The net structure is primarily made up of three layers of metal mesh and is rather a complicated assembly.The inner central layer is actually the "hot" mesh and is terminated as a high voltage source from the circuit enclosed in the lower handle area. The outer two layers are simply connected with the negative of the battery and constitute the ground for a return path to the central "hot" mesh line.
Apr 30, 2014 | Air Purifiers
Tele zapper tz 800 manual
Nov 28, 2013 | Lands Phones
Is it my video card?
this is the problem of screen cells damage,there will be no external crack or anything
causes:-
screen jamming,or displacement of screen layers,water threw the screen,hit to screen,close laptop heavly
solution:-
replacement is the only solution
for more
http://arlingtonvacomputerrepair.com/blog/2013/02/12/three-common-causes-for-laptop-screen-replacement/
Jun 12, 2013 | Computers & Internet
My toshiba L35-S2161 the monitor only displays lines in colors, what to do to fix it
Since you diagnosed by using an external VGA monitor, you now know the fault lies in either the Video Cable, or the Display Assembly.
Your graphics chipset is good.
(Also known as GPU. Graphics Processing Unit )
A) Video Cable:
(Toshiba = LCD FL Cable )
See if the connections are good. Check the motherboard side connection of the Video Cable, AND the LCD screen side connection.
A loose connection can do this.
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/taking-apart-laptop-1.htm
2) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/remove-notebook-screen.htm
(On both links above you can click on the photos to enlarge )
Observe the sheath of the Video Cable for obvious signs of damage.
If the cable looks pinched, stretched, or torn, the tiny wires inside the cable may be damaged also.
Best method is to remove the Video Cable, and perform a continuity test of the wires inside the cable, with a multimeter.
(An economical unit can be purchased for around $8 to $12.
Analog or digital is fine )
B) Display Assembly:
Video Cable checks out OK;
1) Check the connections to the screen Inverter board.
Make sure they are tight. Make sure the Inverter board does not appear to be damaged.
2) Screen Inverter board:
Primer;
An LCD screen does not produce light. It needs an additional light source.
http://en.wikipedia.org/wiki/LCD_screen
A Backlight is the additional light source.
A Backlight is usually a CCFL, or a series of LED lights.
The Toshiba Satellite L35-S2161 Notebook PC, uses a CCFL for a Backlight. (Uses 1 CCFL)
CCFL stands for Cold Cathode Fluorescent Lamp
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm Thick, and is close to the width of the LCD screen in question, Long )
A screen Inverter converts the power (Electricity) from the laptop, for the Backlight and LCD screen.
It is located behind the Display Mask, (Display Bezel), and mounted towards the bottom of the LCD screen.
http://www.zkarlo.com/selected-zkarlo-part/inverter-board-p2215.php
A bad screen Inverter usually causes a garbled display, or doesn't light the Backlight up.
To test a screen Inverter you need a sensitive multimeter, or use a spare Backlight bulb that is known to be good.
Bulb lights up the Inverter is good, the Backlight in the LCD screen assembly, is bad.
[ The LCD screen is composed of layers. These layers are held in place by a metal Screen Frame. {Resembles a picture frame }
The Screen Frame comes apart.
Screws are removed, and the Screen Frame comes apart in four pieces, (Four sides), or the Screen Frame comes apart in two pieces as an Upper half, and Lower half.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/big/satellite-L35-screen-08.jpg
The Backlight bulb is taped to one side of the LCD screen layers, and is under that side of the Screen Frame.
The LCD screen layers MUST be kept aligned, as they were from the factory. For this reason alone, it is tedious for an experienced technician, and is usually not done at the consumer, or DIY level.
http://www.zkarlo.com/selected-zkarlo-part/lcd-cable-p2216.php
More in a Comment.
Regards,
joecoolvette
Feb 05, 2012 | Computers & Internet
I have a acer 4740g laptop.I ve got display problem.It shows several lines and i cnt work on it.Recently it got little pressed on its display.Can any1 help me?
Hello shreejan_man
First thing to do is to test the screen. Also you have not mentioned if there is any cracks or damages.
Plug the laptop to an external monitor (any type will do). If the display on the external monitor is OK then it means the laptop screen is damaged.
If the display on the external screen is the same as the laptop then the problem is internal with the graphic chip or the video contacts.
this laptop is not that old since acer released this model last year. Check you warranty status on it. Some acer laptops come with two year warranty. Check the laptop carefully, if there is no sign of physical damage, (cracks, chips ...) then take it back as a warranty issue.
Good luck
please leave comment, vote if this helped.
Feb 24, 2011 | Acer Computers & Internet
Broken lcd, how can we go about it.
Call HP to determine if the unit is still in-warranty, and they will be replacing it. Otherwise, you may have to upgrade it through their Out-of-Warrranty programs.
Feb 13, 2011 | HP Compaq Presario V2555US Notebook
Hello, I have an Acer Aspire 1356LMi laptop. It
This problem is mostly likely with your LCD screen. It needs to be replaced. I suggest you connect your laptop to an external computer monitor and see if you still see the same issue on the external monitor. If you don't see it, then for sure it is not your motherboard or graphic chip. It has to do with your screen. In rare cases this can also happen if your wiring for the LCD screen is going bad or damaged.
Once you connect the external computer monitor to your laptop, turn your laptop on and located the "FN" and "F4 or F5 key depending on the laptop model" key on your laptop. Hold FN down and hit the F4 key once and see if the screen switches to your external monitor. If not, hit it again and wait.
Some newer laptops auto detect external monitors when they are connected to one.
May 14, 2010 | Acer Aspire 1350 Monitor
Crack beneath screen
I hate to bring bad news but it's better cruel truth than sweet lie.
You got so-called "physical damage" of your LCD panel. Surface that you can touch and one that looks intact is just a protective layer. Behind it is fragile class of LCD panel. Sometimes kids tap toy into the screen and parents later guessing what's wrong with TV.
No manufacturer (that covers first 12 months) or extended warranty will cover this repair. Technician will show up for free of charge, take a pictures of the screen and leave you with this problem. Whole LCD panel have to be replaced and part alone could cost up to 80% of cost of new TV.
Unless you can prove that this is shipping damage (I doubt it because it is not that you calling retailer very next day after purchase) - there is nothing that you can do to get out of this situation cheaply.
Still you need to call manufacturer customer service and have technician from authorized service center to show up and inspect it. Maybe we both wrong and you have a case of defective panel. Really hard to determine without seeing pictures of how your LCD looks like.
Sorry again and good luck!
Russ.
Apr 06, 2010 | Sanyo 42 in. LCD TV
The dryer has ruined many of my clothes, straps and tank tops get caught on the lint filter and then twist until they tear apart. how can i fix this?
Purchase a lingere mesh bag.
Put delicate items in the mesh bag (has a nylon zipper) and dry.
Purchase two or three at Target, WalMart, etc.
Oct 06, 2009 | Dryers
"E1" problem
I would request you to please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Hope this helps resolve the issue.
God Bless
Jul 09, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
264 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
