Question about Memorex M-Flyer 1GB USB 2.0 TravelDrive
My computer wont detect my USB flash drive
When I plug my USB flash drive into my PC, the computer doesnt detect that its in the USB port. Therefore, I cant access any of my files on my flash drive. I need to know how I can access these files so I can, at least, store them on another storage device.
  • 2 more comments
  • Anonymous Dec 09, 2008
    ugs it sucks
  • Anonymous Jan 30, 2009
    I PLUG INTO THE USB SLOT I CANNOT GET ANYTHING TO SHOW ON THE COMPUTER
  • Ashish Dwivedi
    Ashish Dwivedi May 11, 2010
    Please tell me the OS.
  • Anonymous Mar 20, 2014
    the light on my 4GB usb turns on for about 3 seconds then turns off. the computer seems to know it was plugged in but i cannot access it.
    Novelist:
  • 151 Answers
I) try to put the usb drive in some other ports(such as usb port present on the backside of yur computer tower) and check whether your computer is detecting the drive.....
ii) if not there is sureluy some problem with ur usb drive, replace it  or repair it..., you can even try putting another usb drive(if you have an spare one...)
Thanking you
M. Sridhar
Posted on Dec 31, 2008
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to solve usb not reconized error in sony vgn-s36gp?
Hello
Disconnect the flash drive from your computer, then plug it into a different USB port. On occasion some USB ports do not detect inserted equipment (either because the port is damaged or because the flash drive is not supported by the particular connection).
Connect the flash drive after the computer has powered on. If you plug the drive into the computer before starting the system, the computer may not detect the USB device.
Open an Internet browser and navigate to the drive manufacturer's website. Although most USB flash drives are plug-n-play, the computer may not have the appropriate drivers installed, which means you must install the driver before the system can use the flash drive.
Select the "Support" option, then choose "Drivers and Downloads". Click on the model of flash drive you are using, then the operating system. Click on the driver download link and wait for the driver to download to the computer. Double-click the downloaded file to load the installation wizard. Accept the license agreement, then follow the prompts to install the driver. Restart the computer and the system is ready to use the USB flash drive.
Oct 12, 2010 | Sony VAIO VGN-CR220E/P Notebook
I can not open my usb flash drive. computer unable to detect flash drive. what do I do?
try another usb port 1st,preferably on the back side of the pc.If it still doesnt work try it on another pc.if it doesnt work on aother pc its more than likely bad.
Aug 20, 2010 | Computers & Internet
Clicking sound when I plug in hard drive and computer does not pick it up. What's wrong?
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Hope this helps you out.
Nov 23, 2009 | Western Digital My Book Essential Edition...
Integral ide external HDD reader - blue light wont stop flashing, and wont read all data - any ideas
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Nov 20, 2009 | Akasa Plastic 60mm to 80mm CPU/ Case Fan...
SimpleTech 320GB External Hard Drive software.
The link to the driver that you requested is this:
http://www.simpletech.com/support/support_downloads.php
if it still doesnt work after doing all these, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
Try to keep me posted about the problem.
Nov 19, 2009 | Computers & Internet
When I plug my flashdrive in it wont recongnize it and it wont even light up anymore. It just worked the other day and now it doesn't! Whats wrong? Please help all of my school work is on it!!
You can also try it out on a friend's system.
Kindly keep me posted about the problem and let me know how it goes.
Nov 18, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hi all pls. my USB PTY 8 gb. My laptop not reconized. can you help! thank Frank.
Nov 16, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I have Toashiba laptop Satellite A135-S2276. The laptop doesn?t recognize my USB flash drive. Apparently the device was detected by Windows because as soon as I plugged it in, a balloon pooped up and it...
Check it on another computer. if it still doesnt work then your backup is gone. if it does work maybe you should take it in. also try other accessories in that same port. if other stuff doesnt work then you'll probably need to fix the port. also check the drive on any USB ports in the back of you pc.
Regards
Jul 01, 2009 | Toshiba Satellite A135-S2276 Notebook
Memorex M-Flyer 1GB USB 2.0 TravelDrive Logo
794 people viewed this question
Top Memorex Electronics - Others Experts
Stu Morris K
tdk1988
Are you a Memorex Electronics - Other Expert? Answer questions, earn points and help others
