Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How to add additional garage door opener safety sensor
I would like to know if it is possible to add an additional safety sensor to my garage door opener. I have a LiftMaster and it already has one set of IR sensors that are mounted 6 inch of the floor.
My new van is almost as long as the garage space and I am afraid that I'll close the garage door on it. I already have a laser paring aid but I want to add another layer of insurance against a demaged car.
Have anyone try adding an other pair of safety sensor? I would like to add a pair so that the bumper of my van will block them when it is not parked correctly. Other suggestions are welcomed.
Thanks.
    Champion:
  • 244 Answers
Cant be done. put parking bumper on flor so you know you pulled in far enough. you are only one I know who installed parking laser. I don't. If customer isnt home when I install gdo, how do I aim laser. What about when they get new car. They want you back for free to adjust, No way.
Posted on Jan 15, 2009
D1000 closes holding wall button only, sensors clean and same, bypassed them it still did it, remotes don't work
This sounds like a problem with the safety sensors; either due to a blocked path between the safety sensors, condensation, mis-alignment, dirty eyes, loose wires at the sensors or at the motor head, or just bad safety sensors. When the infra-red safety sensors are malfunctioning, usually one of the sensor lights will be blinking or a blinking red light will show rather than green or amber. The sensor lights need to be solid and not dim or flickering.
When the sensors are at fault, the remotes cannot close the garage door; they can only open it. You may find that the door will only move an inch or so in the close direction. When this happens, your garage door will only close by holding down on the wall button until the door fully closes. This method is the only way to override the safety sensors and close the door. This is also a direct clue that the safety sensors are the problem.
Also, try unplugging the garage door opener and re-plugging the unit back into the outlet. This can act as a reset and may reset the sensors. If none of this works then you may have to replace the sensors or possibly the logic board inside the motor unit.
Aug 20, 2017 | Building Materials
Garage door opener not working
Sensor must show steady light to close circuit and let opener work. If aligned, then there is a loose or broken wire. Try reaiming first to get steady light. Then check all wires . Another way to test and prove that is the issue is if u hold down the wired button at ur back door and the opener closes, then it is sensor issue. Good luck.
Apr 11, 2015 | Genie Company Genie Garage Door Opener...
Chamberlain whisper drive bulbs keeps burning out
I had a similar problem on my Liftmaster units made by Chamberlin. I would leave the garage door open for hours during the day so our dog and children can enter the house through our garage and laundry room. Everytime they come into the garage the Light's would go on because of the safety sensors are "tripped" at the bottom of the garage door tracks.
I turned off this feature and my lights are lasting much longer now. Over 1year in fact. To turn off and on this feature, make sure the opener light is off, then Press and Hold the Light Switch on the Wall Control Until for about 10 seconds till the light goes off. This deactivates this sensor from turning the lights on, but does NOT deactivate the sensor for Stopping the door if something is under it. Safety is still preserved.
Additionally, my door opener would vibrate while operating, and need to be aligned - I did this and also prevented the bulbs from "shaking". As we know the light bulb filaments are brittle especially after some use - this I think also helped lengthen the life of my lights on the opener.
Jun 30, 2012 | Chamberlain 1/2-HP Whisper Drive Belt...
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
When garage door is opening the safety sensors activate and starts closesing the garage door. They should activate when I close the garage door.How can I correct this action?
How do you know it is the sensors? Has this opener ever worked properly? Do the main lights flash 10 times when the door reverses? If the opener worked before have you had it apart or done some work to it?
Jan 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Need to add obstruction sensors to an older Craftsman Garage door opener that never cam e with them. Is this possible?
Generally not. To get the sensors alone would cost very near the price of a new unit equipped with video sensors. You could verify this with Sears.
tom
Sep 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 41A3625 garage door opener safety "eye". Buying a new home and the inspector informed us that there is no safety eye system on our garage door opener. It appears to be a 1995 model (at the bottom...
Your opener was manufactured before there were safety sensors and there is no way to add them. You would be miles ahead to replace the opener with a new state of the art model.
Sep 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Light does not come on when it is supposed to
Great call Marty! I had noticed the amber LED above the learn button was blinking with one pulse, which the troubleshooting guide noted as being a problem with the sensors. Finding that one tiny paragraph in the manual and following the instructions of holding the wall-control light button in for 10 seconds reprogrammed it and the functionality is returned. Thanks!
Jan 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens only 6 inches and stuck
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
My light bulbs keep burning out prematurely on my garage door opener.
This is a logic board issue. You can purchase a replacement one at searspartsdirect.com. Enter in your model number and a parts list will come up. This is a fairly easy install, make sure and unplug the unit first. You will have to reprogram the remotes. Thanks BB
Feb 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
661 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
