I have this C51GU01 MOBO
OCZ Platinum 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit Desktop Memory - Retail
Can I use this ram to upgrade it?  Second question is can up update the CPU to a faster dual core?  Thanks a bunch!
  • caensminger Nov 24, 2008
    Thanks a bunch!!!  Now all I need is some one to install it =)  I have never installed a cpu.  Do you think I will need a new fan as well?
    Thanks a bunch!
  • 4,806 Answers
The memory will do fine, as for the CPU i think it can support up to 4200+
regards
Posted on Nov 24, 2008
  • 13,433 Answers
Yes the memory you have selected is supported, and yes you can also upgrade the processor to a dual core processor AMD Athlon 64 x2 (dual core) Just make sure its for the socket 939 but don't get too new of a cpu, the latests ones may not work.
  • 1,879 Answers
Memory : yes
  • Four DDR DIMM slots
  • DDR 333/400 MHz dual channel
  • Max Memory 4 GB
  • cpu : no (the board supports AMD only)
  • AMD processor
  • Socket 939 package
  • 2006 Performance FMB
  • Posted on Nov 24, 2008
    • monk3ybidzness
      monk3ybidzness Nov 24, 2008
      oops thought you are referring to an Intel Duo
    • 101 Answers
    Memory Support
  • Max Memory 4 GB
  • Yes you can the memory is supported
    Yes a socket 939 amd processor dual core will fit this model.
    P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
    http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
    1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
    Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
    Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
    and if you click on the CPU Support List you see that it does not support Dual core processor :(
    May 06, 2011 | ASUS P4VP-MX Motherboard
    What kind of RAM ( ie DDR , DDR1, DDR2 )is supported by d856gsa ;
    Intel D865GSA has two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets It Support for DDR-I 400, DDR 333, and DDR 266, Support for up to 2GB of system memory max CreativeTECH
    Jan 05, 2011 | Intel D865GSA (BOXD865GSAL) Motherboard
    I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
    Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
    Hope this is what you are looking for,
    Cheers,
    Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
    Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
    Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
    From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
    Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
    4 GB max 4x1024 184pin
    Hope this helps.
    Aug 26, 2009 | ASUS PSCH-L Motherboard
    Upgrade of RAM
    184 pin DDR DIMM is the correct information :) The bus speed of the ram would range from PC 2100 - PC 3200. I assume the Max amount of ram will probably be 2gb though unless your motherboard specifies a higher amount.
    Mar 22, 2009 | Computers & Internet
    D865GSA intel mother board supports DDR1 or DDR2 ram
    Straight from intels web site...
    Two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR 400, DDR 333, and DDR 266 Support for up to 2GB of system memory
    Mar 09, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
    Memory confusion different readings
    It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
    Jan 17, 2009 | Mach Speed (S755) Motherboard
    MS9317e+ manual
    CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
    400/533 MHz FSB Chipset SIS 651 + 961 MS9317E+
    SIS 651 + 962 MS9317E+(USB)
    MuTIOL® Delivering 533MB/s Bandwidth Memory Supports two 184-pin DDR DIMM maximum size up to 2GB
    Supports two 168-pin SDRAM DIMM maximum size up to 2GB
    Support DIMMs of DDR333/DDR266/PC133 CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
    Support DIMMs of DDR333/DDR266/PC133manual for this board is no longer available but above is your mobo info
    Nov 01, 2008 | Matsonic MS9317E Motherboard
    Memory Issue
    You could try lowering the Cas latency. Just boot into the bios and try lowering the cas latency up by .5 For example, if it's running at 2.0 change it to 2.5 or 2.5 to 3.0 Yes this will slow down your system, but it may be a more stable speed for the ram to run at. You could also have bad ram, or maybe your problem isn't ram related at all. It's possible your motherboard is the cause of all of your problems. Peter
    Oct 04, 2007 | ASUS P5RD1-VM Motherboard
    Computers & Internet Logo
    66 people viewed this question
    David Payne
    David Payne
