The gun won't work right
As a safety precaution, nailers have incorporated a safety foot that will prevent the gun from firing unless you push down hard. Some guns also have a system where the gun will not fire at all if there are no nails in the gun. To dry fire this type of gun you must pull back the pusher or open the side door. If nails do not feed properly, check for wrong nails, bent rails or weak pusher spring. If all is good with rails and pusher, suspect that the driver/piston is not at top of cylinder and lower part of driver blade is preventing nails from advancing. Remove airline and push the driver to top and retest. If driver is slipping down the cylinder under its own weight, replace oring. Good luck
