Question about Refrigerators
Broken refrigerator drawer support pin
Whirlpool Refrigerator Model ED25PQ XDN01; serial no. SF1218599
The front left support pin for the 'Crisper" drawer has broken off. Is there a replacement part and how do I remove the old broken pin and install the new one?
  • bramberg Nov 24, 2008
    Still need a solution, not a piggyback question.
    Brigadier General:
  • 6,966 Answers
Hi again,
It would seem that you are unable to view my subsequent postings in your Premium problem. Pls find excerpts below:
Cheers.
I am afraid that we have a bit of a problem. It would appear that when you "removed the base by twisting it out.", the mounting hole could have been enlarged and therefore the new shelf stud would not have anything for its lock to latch on. The locks would be the 2 metal tabs below the base. Unfortunately, the solution would call for reaching behind the wall which is impossible due to the construction and put an insert, a washer with smaller diameter for the locks to latch on.
A workaround would be to install a filler on the enlarged hole. The idea is to reduce the diameter enough for the locks of the shelf stud to latch on to something. The filler could be anything, a small diameter tubing cut horizontally and fitted over the hole as a gasket, water resistant tape, even soft leather cut out as a patch from an old golfing glove. The idea is to reduce the diameter of the hole for the stud's lock to purchase a hold on the other side of the wall.
Additionally, it might be to your advantage to put some quick dry adhesive, epoxy or superglue under the base that would attach to the wall.
Posted on Nov 30, 2008
I have a Kenmore 2 door,freezer on bottom, mod# 795.77309600,the shelf that holds the crisper draws cracks,front & back corners, also the back,middle. this is the 2nd time for me. Is there a solution??
Posted on Nov 24, 2008
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
Water in bottom left crisper drawer and under drawer
I'm sorry to say that it sound as though your door gasket may no longer be sealing correctly.
For me, it's simply a task of getting a replacement gasket for that make and model.
To remove the old one you would, simply, peel the inside of the gasket toward the outside of the edge of the door revealing the mounting screws. Remove these screws all the way around and replace with the new one in the same fashion...
The reason that I recommend this is that humid air outside of the refrigerator can seep past a worn gasket and condense on the inside surfaces making its way to the bottom and into those drawers.
Feb 16, 2014 | Whirlpool Refrigerators
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Model # ET22DK, water is collecting underneath the crisper drawers.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | Whirlpool Refrigerators
How do i find the model number on my GE Profile Side by side
Hi, you can locate the model and serial number of your fridge by looking at
1. Inside the refrigerator or freezer, on the left or right side wall.
2. On the face frame of the refrigerator body.
3. Behind the lower crisper drawer.
4. Behind the lower toe kick-plate.
Take care
May 19, 2010 | Refrigerators
Freezing in left crisper drawer.
If you have had a DOE upgrade the fix is availiable from LG
Here is the service buliten # CREF20090877.
Contact LG @ 1 800 243-0000 for repair.
In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
Jan 19, 2010 | LG LFX25960 Bottom Freezer French Door...
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
Refrigerators Logo
528 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
