Question about Goodman GMS90703BXA Heater
Furnace fails to operate correctly,no LED signal
The heating cycle doesn't begin unless the emergency switch is switched off for several seconds then switched back to the on position.. After the heating cycle ends,it will not begin again until the emergency switch is again toggled .The fan runs continuously.
  • Edward Moore Jr. Dec 08, 2008
    The inducer fan runs constantly.The heating cycle doesn't begin unless the electric is turned off for several seconds then switched on again.And or when the blower compartment door is removed,and the door switch taped down,The heating cycle will begin if the hose to the right side pressure switch is briefly
    removed.There are 2 led flashes.
    Genius:
  • 1,199 Answers
There may be water in the pressure switches from condensation take off shake them upside down ro remove water replace reset then turn on ,also make sure there is nothing blocking the intake pipe or exhast pipe
Posted on Dec 08, 2008
    Sergeant:
  • 399 Answers
The required power is not getting to the machine internally.as when you on/off the switch the current flows and then stops producing that same flow of current.check out the circuit bard,
Posted on Dec 06, 2008
  • masterexpert Dec 06, 2008
    Not enough air flow across heat exchanger due to but not limited to would be a good start.
    blower speed not turning correct RPM.Squirrel cage lobes dirty, (not picking up right amount of air )Belt loose if it's a belt drive system. if you have central air dirty indoor coil, plugged air filter. Return air /supply air restricted or  duct work restricted.Etc.Etc.
    Gas valve overfiring causing hotter temperatures.Need to check gas pressures ( would need to call for service on that one)
    Blower relay slow to energizes ( if you have a Time Delay  fan relay ), causing unit to trip on high limit before fan starts.Try running indoor fan in "ON" positon at t-stat to run blower 24/7 then start heat if evrything works ok guessing it's your fan relay.
    Those are some of the more common problems but certainly not all.
Comfortmaker furnace model GUH075 requires resetting for flame to light?
Is this an oil or gas fueled furnace? All heating appliances have several safety switches in the controls. Flicking the on/off switch (assuming you mean the emergency toggle switch) is not resetting the burner. If you pressed a button near the red light,that MAY have been the primary control reset.
Your problem could be anything from the main power switch to one of the many controls with a wiring or sensor issue. Or even a t-stat wire problem.
Regardless, a thorough technician should be checking the entire circuit, from the t-stat to every control in the circuit. Including every wire.
Lastly, a qualified licensed technician should never diagnose without being in front of the appliance. Hope this helped :)
Jan 30, 2013 | Heating & Cooling
I have a goodman furnace GMP100-4 REV B..about a year ago it was not working. The fan would start but it would not ignite. We found out we need a new ignitor and it was a good quick easy fix. Now a ye
Any light flashin on the control board? If not then look for a small fuse blown on the board. See lights a flashing count them flashes
A sampling of various failure codes on a furnace:
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
Nov 29, 2011 | Goodman Heating & Cooling
I have a Goodman GMP 125-5 furnace. It had a 3 light code i replaced the presure switch now it is giving me a 1 light code please help
Oct 28, 2011 | Goodman Heating & Cooling
I have goodman GMP series furance the furnance and gas comes on and fires up then goes out flame sensor is good what else could be wrong
Improper ground from control to burner.
Incorrect electrical wiring, check polarity.
Tubing partially clogged between inducer and proving switch.
Oct 18, 2011 | Goodman GMS90703BXA Heater
Suddenly not working im not sure if there even is a pilot to be lit
Goodman have troubleshooting idiot lights on the board. Look for flashes and count em.
The flash explanations are printed on the backside of the blower cover on most models.
Feb 03, 2011 | Goodman Heating & Cooling
Goodman 95 %furnace keeps saying low pressure is stuck. changed out low pressure switch and high pressure switch and still have same problem.
That thang might be sensing a lazy flame. In other words the flames took too long in the board's opinion to quit sensing the flame. Yall probably need to do pressure tap on the gas valve.
Here is a realistic look at goodman fault codes and what to check fer and I am assuming you are not a tech and don't know this already and am hoping it helps:
Now here is how it should all go down:
Bottom dollar: it all goes back to type of gas, the initial setup, the pressure tap. and how it is wired up to begin with.
This will give you an idea where to start I hope.
Dec 10, 2010 | Goodman GMS80903BNA Heater
My central heating is on lockout and the burner is with red light
A sampling of various codes on a furnace
Interpret five LED flashes to mean your Goodman furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Dec 02, 2010 | Heating & Cooling
The heat turns off after 3 seconds of flame.
There is a flame sensor failure.
Here is the ignition sequence for a furnace. This will help you understand what is happening/not happening.
Thermostat2.gif calls for heat.
draft inducer motor (DIM) starts drawing draft through heat exchanger.
Pressure switch detects proper operation of DIM, and sends signal to board to begin ignition.
(it detects negative pressure)
Ignitor starts ignition attempt and gas valve sends gas to burners.
Upon ignition, flame sensor detects flame and sends signal to board stopping ignition sequence and continuing gas flow for heat mode operation until thermostat is satisfied.
During this sequence the blower motor is brought on, and by using a series of temperature limit switches, the system assures that the unit is operating properly.
(If the blower is not operating, or the airflow is inadequate, the heat exchanger will overheat and trip one or more temp limit switches.)
There is also a "rollout" switch that detects improper flame pattern "rolling out" into the controls compartment.
Now, to apply that to your situation.
If the flame sensor does not sense flame, it shuts down the furnace to prevent a dangerouse gas build up.
With most modern glow coil ignition systems you have one of two failures.
1) the flame sensor is bad and needs to be replaced.
2) the control board is not proccesing the signal from the flame sensor and shuts the system down. In that case the board would need to be replaced.
There is a possibility that a temperature limit or roll out switch is breaking the curcuit, but that would be quite unusual to happen consistantly at three seconds.
Unless you have the ability and tools to test the snesor and board, the next step would be to replace the sensor first, and then the board if that does not fix it.
Oct 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Electric furnace/heater pump/fan unit won't shut off
There are dip switches on the main board.. When you remove the lower panel on the air handler there are instructions to where the dip switches should be for your units fan control. if the switches are in the correct configuration.. The Thermostat may be malfunctioning or not wired properly. and last.. and most expensive.. the motherboard may also be failing.
Jan 09, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
