Question about Dell E153FP 15" LCD Monitor
Monitor nor driver acknowledged
Re-installed Windows XP due to other issues, and after the completion of the re-installation the display settings were way off. No monitor is listed in the device manager area and when I try and go thru display advanced>monitor>, etc, to update drivers (I did find the driver at DELL), but the properties button is unclickable. Anyone?
  • 1 more comment
  • Tufnel May 26, 2008
    I have the same problem, but I can't move the screen resolution slider bar or adjust any other settings. My computer's stuck at 640X480 with 16 colors.
  • anson600 Aug 21, 2008
    I reformated my Dell computer with Windows XP.
    The monitor is stuck at the low resolution. The Display adjustments are "frozen", I am unable to move the resolution slide to a higher number.
    In the "Advanced" mode, I click on the "Monitor" tab and see a "default montior" icon. The "Properties" icon is disabled and I can not install the required drivers for my monitor. Any suggestions?
  • donaldprodie Oct 16, 2008
    monitor working perfectly then not acknowledged by computer after a windows xp re-instalation
  • 624 Answers
If you just want to adjust the display settings so that they are more to your liking go to Control Panel and open Display. When the Display Properties box opens click on the settings tab. Use the slider bar in Screen Resolution to adjust to 1024x768 or whatever resolution your monitor displays best at. To the right use the pull down arrow to select the highest color quality you can select. Then click on the Advanced button on the bottom left and you should see a Monitor tab. Click on that and ensure your refresh rate is 60 Hertz. Save your settings, accept the change confirmation when it appears and your monitor should be good to go. I have about 90 Dell LCDs and the default Windows drivers for the LCDs usually work great.
Posted on Jan 01, 2007
Where can I find a driver/adapter for Advent X19W LCD Monitor?
Goto device manager , uninstall the card. go into control panel and check that the driver is uninstalled from the programs list. Swich of the pc for a minute or two then reboot Windows updares does not download drivers for graphics cards so will not install or reinstall the driver that is causing the issue, 307? Users forget to uninstall from program manger in control panel which is why the card keeps reinstalling with the undesired driver.
Please let me know what happens
Dec 14, 2014 | Nvidia Computers & Internet
Tip
How to install your monitor drivers in Windows 7 1. You will need to access your...
1. You will need to access your computers display settings. This link will show you how to access the display settings
http://www.fixya.com/support/r4290529-change_windows_7_display_settings
2. Click on "Advance Settings"
3. Click on the "Monitor" tab
Note here is where you will is if you have a generic drive installed or not. If it shows Generic or Plug & Play Monitor then you may not have the actual monitor drivers install.
4. Click on the "Properties" button and click on the "Driver" tab
5. Next you will want to click on Update Drive
At this point you will want to select "Browse my computer for the driver software". The reason you want to do this is because if you select "Search automatically for the updated driver software" you will most likely get the default Windows drivers that are already installed.
6. Next you will browse to the driver CD or the place you have the drivers saved on your computer. Note if you just upgraded from Windows XP your old drivers may not work and you will need to find Windows 7 versions of the drivers. However if you have a Windows Vista version of the driver this may work.
After you get the location set click Next
7. At this point you should get a message that states that the drives have been installed.
8. Click Close - Close - OK - OK and you should be back at screen resolution.
Other Helpful Links
How to change your Windows XP display settings
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Mar 08, 2010 | Computers & Internet
My packard bell viseo monitor makes my pic's to wide
This issue is caused by missing drivers. You may need to install the drivers (Video card drivers and the Display drivers), the setup will set the adequate resolution for the display so the images will be displayed correctly.
Oct 05, 2009 | Packard Bell Computers & Internet
Trying to complete Windows XP Restore - Add Driver Re-install
check the graphics card and install the driver for it then your resoulution will change
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | ViewSonic VA902 19" LCD Monitor
Screen will not display
Have you ensured that your display card driver AND correct monitor driver is installed. This is to make sure that your display card only generates signals that your Acer monitor is capable of handling. If you do not have the driver CD for your monitor you can download the software from www.acer.com. The problem is most likely that your display card is generating a refresh rate which your monitor cant handle. Go to your display properties and lower the refresh rate of your display card and see if this solves the problem.
Best wishes,
Graemevm
Jun 29, 2009 | Acer H233H bmid Monitor
Stuck in default monitor setting
After installing XP you have to install all the device drivers. Click here to download Device Drivers.
Thanks, PREM
Mar 29, 2009 | Dell Dimension 2350 PC Desktop
LCD Computer monitor
This problem may occur due to wrong driver of display card or wrong display settings.
Solution:
1- Start you computer in safe mode.
2- Remove display card driver.
3- Restart you computer.
4- Install display card driver (if it does not pick automatically).
Now it should show default settings. I hope it would solve your problem.
Aug 17, 2008 | Gateway FPD2275W LCD Monitor
Windows xp installation
HI,
Here is what the Media test failure check cable eiting PXE ROM means:
Iam sure when we were changing some settings with the BIOS you must have done something wrong.Just reemember if you changed some settings over there.
try change the boot-order in the BIOS
try to disable "network-boot" in the BIOS.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive. To resolve this issue,Isuggest you go through the steps in document CH000229 relating to a similar error message.
Now coming to System32\ntall.dll unknown hard error:
Restart your computer. The ntdll.dll error you're receiving could be due to a one-time, temporary issue and a simple reboot may resolve the problem completely.
If the ntdll.dll error only displays when you use a specific software program, uninstall the program, reboot your computer, and then install the latest version again from scratch.
Update drivers for any hardware in your computer where updated drivers are available. Outdated drivers sometimes cause ntdll.dll errors.
Test your memory for damage. If you're receiving ntdll.dll messages, one possible cause could be a bad memory module in your system. Testing your memory will either identify a problem or clear your RAM of any responsibility.
Perform a repair installation of Windows XP. If individual software reinstallations fail to resolve the problem, a repair installation of Windows will replace the ntdll.dll file. Remember to install all Windows service packs and other patches after this installation.
Perform a clean installation of Windows XP. A clean installation will completely remove Windows XP from your PC and install it again from scratch. I don't recommend this step unless you have stepped through all previous troubleshooting steps and you're comfortable that the ntdll.dll error is not caused by a single program (Step #2). NOTE:a single program or plugin is causing the ntdll.dll error, reinstalling Windows and then reinstalling all of the same software may lead you right back to the same ntdll.dll error.
While extremely rare, if everything else has failed, including the clean installation from the last step, you could be dealing with a hardware issue with your hard drive. If so, replace the hard drive and then perform a new installation of Windows XP.
Apr 20, 2008 | Computers & Internet
Windows xp
same prob but it solved
follow the process
1.load servicepack2
2. all driver
and notice that first u have yo install antivirus then
motherboard
Nov 15, 2007 | Microsoft Windows XP Home Edition
Dell E153FP 15" LCD Monitor Logo
77 people viewed this question
Clive
Clive
Alun Cox
