Question about GE Profile JK915 Electric Single Oven
Convection fan not working
Hi, I have a GE Profile Spectra oven which is 3 yrs. old. I have never cooked in the convection mode and decided to try it for the first time this week. My convection fan inside the oven does not turn and the icon on the control pad shows that the fan is turning. Do I need to call a repairman or is is something simple that I can do? I pressed "convection roast", put in the desired temperature and pressed 'Start". The icons show that the fan is turning but the fan inside does not move. Thank you,Lorrie
  • 87 Answers
Check for a bad fan motor or a jammed blade.
Posted on Jun 14, 2007
Need to know how to use the "self cleaning" method for my GE Profile Spectra oven. Also would like to know how to use the convection part of oven also. Thank-you for your help.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Apr 15, 2011 | Ovens
I have a GE profile wall oven. Electronics work but no heat in both convection and regular mode. any ideas
if power is ok......then element is likely bet.............
but cant see both element packing in at same time...........
check power to both ovens.............
cheers
Mar 27, 2011 | GE Ovens
I Lost the instructions for my GE profile Oven probe. Need advic
I need oven probe instruction and oven conversion time with the convection oven for cooking a forty pound turkey.
Nov 25, 2009 | GE Profile JT952 Electric Double Oven
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
GE Profile convection with light bulb burning out
Multiple possibilities.
  • Being used as a night lite. (continuous use)
  • Not using a light bulb designed for use in a oven.
  • Inexpensive bulb. (very low lamp hour rating).
  • Oven door slamming.
  • Over voltage condition.
  • (My favorite) Light bulb swapping Gnomes.
Please take the time to give this solution a fix ya rating.
clarkco
Feb 22, 2009 | GE Profile JTP18 Electric Single Oven
Never used Convection JTP 5650DI55
Did you try going to the GE website? If not, try it:
http://www.geappliances.com/
When you pull up the website, you can click on the blue down arrow located in the box at the top of the web page, next to the work SEARCH and click on "USE & CARE MANUALS. Put your model number into the next box to the right and hit GO.
If you are having trouble after entering what you believe is the proper model/serial number, you can look at the FAQ (frequently asked questions) section to determine whether you have actually entered the proper number.
Aug 05, 2008 | GE Profile JTP56 Electric Double Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Baking with digital oven
First let me address the temp ... Buy a meat thermometer and test it against the temp set in the oven.  Though that isn't the most accurate, it should prove whether or not it is way way off.
Second.. convection baking takes considerably less time....
Third... elevation plays a key factor on baking but not so much on cooking meat.  Baking above 2500ft elevation takes 20% longer and above.
Mar 08, 2008 | GE Profile JTP18 Electric Single Oven
This is an electric convection oven
I am by no means an expert, but I believe the only thing differenty in a convection oven vs a regular oven is that there is a fan to conduct the heat quicker and more evenly. It has to do with heat tranfer rate. I can't imagine why aluminum foil would cause any problem.
Aug 21, 2007 | GE Profile JT915 Electric Single Oven
GE Profile JK915 Electric Single Oven Logo
1,216 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
