Question about HP Deskjet D4260 Printer
HP D4260 Stops printing
I have a HP D4260 Printer that stops printing after a few pages, sometimes after 1 sometimes 15 or more before it stops. Vista reports that the printer has stopped communicating with the system. I have all the latest drivers installed and have downloaded the HP diagnostic program which reports that there is an issue with the spool when the problem occurs. I have tried setting the spooler to the spool jobs first option, tried the start printing immediately option, and also the print directly to printer option with no luck. Problem occurs while using any of my software packages when printing more than one page.
  • Anonymous Jan 24, 2009
    I've had the same problem with a D4160 for some time now. Why hasn't anyone responded to you yet? Does this site really work?
SOURCE: HP LaserJet 2840: Page 'Too Complex'
Description
The device could not print the current page because of its complexity.
Recommended action
Press ENTER to clear the message.
Allow the device to finish the job, or press CANCEL to cancel the job.
Lower the USB speed on the product by turning off "High Speed USB". Following are instructions on how to do this from the Secondary Service Menu:
To access the Secondary Service Menu press the Menu button.
Now press the #2 button and use the < arrow to navigate to the High Speed USB selection.
Press Enter and then use the arrow key to go to Off and press Enter again.
Press the Cancel button twice to exit the Secondary Service Menu.
Posted on Apr 09, 2008
mspcrepair
  • 169 Answers
SOURCE: hp psc 1210 not working in vista - but diagnostic utility shows all ok - and prints test page
Here is the full-write up on the HP PSC1210. Read through this thoroughly to ensure that you follow all the steps to make it work in Vista, since there is no Vista native driver.
Hope this helps - remember to rate :)
Posted on Oct 02, 2008
SOURCE: Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Posted on Jan 28, 2009
  • 39 Answers
SOURCE: Printer is a Canon MP470 all-in-one, USB
Is your printer hooked up to your network?
Make sure all your settings are correct and try connecting the printer directly into your computer. Then print if it does not work still then comment back and I will be glad to help.
Hope this helped.
-Ryan
-Please rate if this helped
Posted on Feb 19, 2009
leroyal
  • 2120 Answers
SOURCE: HP Photosmart printer 3180 prints alignment page at start up
Replace all ink cartridges to get a successful alignment.
Posted on Feb 25, 2009
When i ask to print all (pages), only the last page gets printed. I have to select and print each page separately to print out whole documents. I'm printing from an Hp using windows Vista 6.0. This...
some printers collate pages, which means they print from the last page to the first page. so that when you pick up the pages from the finished printing tray they are in order.
if you say it stops after the first page, there are a few possible reasons for this.
either you closed the application you were printing from before you finished printing (which sometimes cancels the printing job)
or the computer decided it wanted to cancel the printing on its own, this can happen if the printer has sometimes an error, this error or cause could be a lag between the data transfer to the printer.
try printing without collating the pages, while keeping the application/document open.
and make sure you have the latest drivers.
May 09, 2011 | Lexmark X7350 All-In-One InkJet Printer
How do I stop my HO Deskjet D4260 from printing?
unplug printer first then in the printer Que delete all jobs and check that the last file you tried to print is not corrupt and printer driver is not corrupt restart pc and then it should ok when you power up pc and printer
Oct 11, 2010 | HP Deskjet D4260 Printer
How do stop printer from printing unwanted pages?
there will be an icon on the taskbar on the right corner. a set of pages are saved there when you make use of your printer.. remove all the contents from that are and unwanted pages will not be printed
Oct 05, 2010 | HP Deskjet D4260 Printer
Only prints black and white,it has two new cartridges hp deskjet d4260
You could try to do a power down reset and reinstall your cartridges.
First turn off computer
remove the 2 ink cartridges,
press power to turn off printer
unplug printer from ac outlet
wait 3 minutes
plug back printer
turn on printer
wait until printer stop
reinstall both cartridges
turn on computer
Dec 03, 2009 | HP Deskjet D4260 Printer
Attention light, print stops.
either you upgreat memory or print order less than 50 pages at a time.
Mar 14, 2009 | HP LaserJet 1320n Printer
My HP Officejet Pro L7580 prints one page and then stops
TRY WITH WHETHER THE PRINTER CONNECTED PROPERLY AND UPDATE IS NOT PROPER
Nov 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Doesn't took A4 Page, page torns and come sometimes jammed
Brother change the toner and give the printout hope this may solve
Aug 11, 2008 | HP LaserJet 1020 Printer
My HP 694c hangs while printing
Probably the service station motor is burn out ...
However try to lubricate the carriage shaft with some oil, supposing carriage blockage.
Jan 12, 2008 | HP DeskJet 694c InkJet Printer
HP Deskjet D4260 Printer Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
